Hi all i am currently using a FoxPro caller but would like to move to a new caller with a better remote rang, simple you would think, the problem i have is that the caller in question dose not have the calls i use i a regular bases and will not play the FoxPro files, but will play MP3 format, i was wondering if anyone noes how i can record the sounds and save them to MP3 format so i can put them on the new caller.
Many thanks Dennis.
Help needed please.
Re: Help needed please.
Never tried bit i bet you could do it with a smart phone these days. Try searching 'mp3 converter' on your app store......worth a try
I thinks the Foxpro sounds are in a proprietary file format (.FXP) and I can't think that I've seen a file converter for them.
- some bloke
- NON EMMET
I can't help but wonder if a longer antenna modification on either the remote or main unit might improve the range - that's thinking way back to my rubber duck 10 10 till we do it again days. Bye from Phantomshootingcharley wrote:Hi all i am currently using a FoxPro caller but would like to move to a new caller with a better remote rang, simple you would think, the problem i have is that the caller in question dose not have the calls i use i a regular bases and will not play the FoxPro files, but will play MP3 format, i was wondering if anyone noes how i can record the sounds and save them to MP3 format so i can put them on the new caller.
Many thanks Dennis.
