Angel eye dvr Language selection
Rufus
Post by Rufus » 21 Jan 2015, 13:10
Hi
I have just unboxed my Angel eye Dvr unit for a pulsar 750 but the screen is all in Chinese. Does anyone know how to change it to English?
MrNewbie
Re: Angel eye dvr Language selection
Post by MrNewbie » 21 Jan 2015, 19:20
1) Plug the silly little camera/mic into the AVI/in jack.
2) Set the SWITCH (bottom left side to N)
3) Turn on power. You should see video on screen.
4)Hit the ESC button , scroll to bottom right side of screen to the little gear icon, use the << >> buttons.
5) Hit OK.
6)You now have 8 little boxes, that you can not read. (:
7) Using the same << >>, scroll to the 2nd one up on the bottom right.
8) Your done.
Between steps 4 and 5, every icon on the bottom has its own menu...every icon has a different menu. You hit ESC then scroll around..then say ok for every individual screen icon
Damn, I'm good.
How do I know this? Mine came in yesterday too!
Mine will not charge through the computer USB port.
So, if you are having problems battery wise, just use the charger that came with it.
It is a flakey little gadget, but it does record at 800x600 res...not bad for the price, but a PITA to figure out.
Rufus
Post by Rufus » 22 Jan 2015, 04:16
Thanks Bud
Got it sorted
