WDR 700TVL SONY CCD EFFIO-E FPV ultra low lite Mini Camera.
code9ster
Post by code9ster » 27 Oct 2017, 09:34
I am trying to get the irony filter off any suggestion? I have tried a hair dryer no help at all. I assume from everything I've read it needs to be removed.
Re: WDR 700TVL SONY CCD EFFIO-E FPV ultra low lite Mini Camera.
Post by phoenix » 27 Oct 2017, 14:14
This is the UK, most of our humour is irony, but I didn't realise that it came already fitted to cameras :?
Post by some bloke » 27 Oct 2017, 15:31
How ironic - predictive text at its best. :angel:
There'd be a lot of people suing the manufacturer of a hair dier that gets hot enough to melt the adhesive that glues the filter to the sensor.
Hotter options are a soldering iron with some solder to help spread the heat, or put a small coin on the cooker ring to get hot then quickly transfer it to the filter, after a few seconds try pullling the filter off.
code9ster
Post by code9ster » 27 Oct 2017, 16:49
Thank you all I will try the soldering iron and yes predictive text is on I think mine is at a pre school level always messing up I already knew how the responses would be interested have been reading posts on here for months trying to get a grasp on diy nv
code9ster
Post by code9ster » 29 Oct 2017, 04:03
:thumbup: soldering iron worked great!
Post by some bloke » 29 Oct 2017, 04:16
code9ster wrote::thumbup: soldering iron worked great!
:angel:
