Tasco Target/Varmit Series No-good for add-on
Frogman Ladue
Postby Frogman Ladue » 08 Dec 2015, 02:15
The Tasco Target/Varmint series runs 1/8 MOA cross hairs. 16mm cam lenses have a hard time focusing on the cross hairs. 12mm will not focus on the cross hairs. The cross hairs are too thin for what we need in a add on project scope...you'll never see the cross hairs at night.
Re: Tasco Target/Varmit Series No-good for add-on
Postby some bloke » 08 Dec 2015, 05:37
I prefer to use 25mm board lenses. They are a higher mag so you can use less scope mag - and the crosshair is also made larger.
Frogman Ladue
Postby Frogman Ladue » 08 Dec 2015, 19:11
I just stepped down from a 16mm to the 12mm. It was a high mag scope, and I needed the extra wiggle room. I was making too many field adjustments with the 16mm lens...I'm sure the 25 would be worse.
Return to “Best scope for nightvison add-on.”
