Ward D 700
patterdale31
Ward D 700
Post by patterdale31 » 16 May 2017, 16:17
Suggestions for a scope for ward D 700. Only had a spare Nikon sterling mount master and very disappointed with view at night through it.
Re: Ward D 700
Post by warbucks » 16 May 2017, 19:29
Any of the scopes that's known to work well with n/v will work well with the Wardy 700.
Hawke sidewinder 4-16x50 would be around my first choice, certainly if buying new as a ten year warranty, then mtc mamba-lite, viper, AGS 3-12x44, 4-16x56---------all of these's scopes work to ABOUT the same level with the Wardy 700------the Falcon m18 3-18x44 works well but the cross hair is too fine, however if a 16mm lens is fitted in the Wardy it work very well.
patterdale31
Re: Ward D 700
Post by patterdale31 » 16 May 2017, 19:36
warbucks wrote:Any of the scopes that's known to work well with n/v will work well with the Wardy 700.
patterdale31
Re: Ward D 700
Cheers Dave. Loads of info to look into with scopes now.
lecoper
Re: Ward D 700
Post by lecoper » 17 May 2017, 13:08
Anyone used the new mtc viper pro. Thought about buying the higher mag one in the hope that it would double up as useful on the range and with wdv800 add on.
