Best scope for NV add on
Fox Hunter
Post by Fox Hunter » 18 Oct 2011, 18:46
What's the BEST scope for use with an NV add on?
Does it matter or make any difference if it's used with GEN 1,2 or 3?
What actually makes it the BEST?
Who's got one for sale cheap? :lol:
MothersMilk
Re: Best scope for NV add on
Post by MothersMilk » 18 Oct 2011, 18:56
Nooooooooooooo :lol:
Thought I should say something vaguely constructive, so - I've tried quite a few scopes with a few monoculars and don't think I've noticed anything better or worse (mag for mag).
Some sort of focus adjustment is preferable but if you shine enough IR at the target they all seem to work just fine ;)
Donated in a wild burst of enthusiasm for a fledgling forum....Good luck all!
Bangbang
Post by Bangbang » 18 Oct 2011, 19:59
Side parralax is a must IMO front is to hard to reach and you can block or reflect the ir. I use a bushnell but have tried a few mambas were good with the nv bit not good enough with out for me. Ags seem to work well to
MothersMilk
Post by MothersMilk » 18 Oct 2011, 20:01
Please please sticky this topic :D
Edited to say: There is a God! :D Thank you, Thank you! :D :D
Please check the new section lads and lasses:
"Best Scope for NV add on"
Fox Hunter
Post by Fox Hunter » 18 Oct 2011, 21:44
Bangbang wrote:Side parralax is a must IMO front is to hard to reach and you can block or reflect the ir. I use a bushnell but have tried a few mambas were good with the nv bit not good enough with out for me. Ags seem to work well to
I've heard the mambas had a good name with an add on and was thinking along those lines but I'd also be shooting alot in daylight so you've thrown a spanner in the works there.
When people say expensive scopes don't work well with add on's because of the 'expensive coatings' what is the problem?
Is the picture blury or do they just need more IR illumination to see anything?
Fox Hunter
Post by Fox Hunter » 19 Oct 2011, 11:42
Sounds as if the shortlist is Mamba, AGS or Bushnell then???
camo304
Post by camo304 » 19 Oct 2011, 12:19
+1 for the AGS gang
gizzard
Post by gizzard » 21 Oct 2011, 19:01
ive got ags tactical on my nv rifles, good strong crosshairs. tried the mamba but it was not as good as ags. the best image i had was from a edgar brothers 3.12.52 optimate but it had no side parallax sadly.
Silent Shooter
FOUNDER
Post by Silent Shooter » 21 Oct 2011, 19:05
gizzard wrote:ive got ags tactical on my nv rifles, good strong crosshairs. tried the mamba but it was not as good as ags. the best image i had was from a edgar brothers 3.12.52 optimate but it had no side parallax sadly.
Welcome to the forum gizzard :D
Geoff
gizzard
Post by gizzard » 21 Oct 2011, 19:34
thanks bud.
