fitting ej230 with cs lens
andy6149
Post by andy6149 » 29 Dec 2014, 14:06
Hi, I'm going to use my ej230 as a spotter, already have a 5-100 cs lens and have ordered the adaptor from stock optics to go from m12 to cs. I know there are options to bin the ej housing all together but I don't want to do that. Without access to a lathe or CNC machine what is the best way people have found to shorten the threads to allow cs lens to focus? I'm thinking bench grinder?
Dirt1427
Re: fitting ej230 with cs lens
Post by Dirt1427 » 29 Dec 2014, 14:25
I'd go some blokes eg230 addaptor thingy there solid
Cheers Dan
Torchwood
Post by Torchwood » 29 Dec 2014, 14:27
Hacksaw, than sand it down. 5mm or so should do it. You'll be better off with a c mount lens as it sits further away from sensor.
Toni
Dirt1427
Post by Dirt1427 » 29 Dec 2014, 14:27
Plus with that there's no need to shave the eg down
sikapup
Post by sikapup » 29 Dec 2014, 14:36
i took a tad under 5mm off with a junior hacksaw and then faced it up with a fine file.
worked a treat ;)
atb paul
Post by some bloke » 29 Dec 2014, 16:31
You'll be very lucky to get any CS mount lens close enough to the sensor which is quite a way inside the front of the camera tube.
sikapup
Post by sikapup » 29 Dec 2014, 17:01
sikapup wrote:i took a tad under 5mm off with a junior hacksaw and then faced it up with a fine file.
worked a treat ;)
atb paul
sorry delete this advice, i am talking about e700 housing NOT ej230 spoke before thinking(as usual) :oops:
andy6149
Post by andy6149 » 30 Dec 2014, 00:56
I was sure it had been done with an ej230 and cs lens
Post by some bloke » 30 Dec 2014, 01:54
andy6149 wrote:I was sure it had been done with an ej230 and cs lens
I tink it can be done with Rolaids because his tube is possibly shorter than the EJ230 tube.
andy6149
Post by andy6149 » 31 Dec 2014, 16:33
So.... Cs adapter arrived today, using dremel I took slightly over 5mm off the ej230 body and attached my 5-100 cs lens - all good! As a bonus I also discovered with this lens I can still mount it behind the scope, the lens is right up to the eye piece but once I refocus the lens it works great so I can use the rig either on or off the rifle
