DIY Broom Pro dedicated digital NV rifle sight Library
Locked
Radagast
junior librarian
Post by Radagast » 14 Feb 2016, 11:28
Q: What is a Broom Pro.
A: The Broom Pro is a home built dedicated digital night vision scope. The name may be a play on words based on the Drone Pro commercial dedicated digital night vision scope.
Q: Who invented it?
A: UKNVF member Torchwood.
Q: Why would I want to make one?
A: It is the simplest full home build digital scope design, requiring minimal DIY capability. It is probably a stronger design than the Photon Extreme and thus can be safely used with larger, heavier lenses.
Q: Is the image better than the Photon Extreme?
A: No. The Photon has a more sensitive camera (larger pixels). The near eye display is the same for both, so using the same IR & front lens, the Photon Extreme will perform better. The Broom camera has more (smaller) pixels, so if more IR is provided to compensate, then potentially the Broom will give greater detail.
Q: Where do I get the parts?
A: UKNVF member Some Bloke can provide the camera housing body. UKNVF member Splatty can provide the Near Eye Display and the retaining plate for same. UKNVF trader Sure24 can provide the camera. All other parts can be sourced from Ebay.
Q: So I have a question about....
A: Read the threads below.
Q: My question wasn't answered..
A: Start a new thread in the DIY NV forum.
Original thread by Torchwood:
http://nightvisionforumuk.com/viewtopic ... 29&t=10004
Torchwood's second build:
viewtopic.php?f=29&t=10451
Demonfox1's build:
viewtopic.php?t=10696
Gypo's builds:
viewtopic.php?f=29&t=10564
viewtopic.php?t=11081
Hamish's build:
viewtopic.php?t=10780
http://nightvisionforumuk.com/viewtopic.php?t=11034
Paul 1961's build:
viewtopic.php?f=29&t=11292
Paul 1961's Broom Pro add on:
http://nightvisionforumuk.com/viewtopic.php?t=11805
Reaper1064's build:
http://nightvisionforumuk.com/viewtopic.php?t=11841
viewtopic.php?f=29&t=11740
Battery discussion:
viewtopic.php?f=29&t=10697
viewtopic.php?f=29&t=6764
viewtopic.php?f=29&t=7538
viewtopic.php?f=29&t=9088
viewtopic.php?f=29&t=14013
viewtopic.php?t=9809
viewtopic.php?f=29&t=13948
viewtopic.php?f=29&t=5694
Battery level OSD:
viewtopic.php?f=29&t=10565
General discussion:
viewtopic.php?f=29&t=11185&start=10
Near Eye Display discussions:
The Oriscape VF-2C is the NED the Broom Pro is designed around. It is the best combination of high resolution and low price at this point in time.
The simplest solution for a first time builder is to buy the VF-2C display from Splatty that has had the components potted (embedded in resin) to prevent water entry and recoil damage.
In depth info on modding and installation of the VF-2C is in the following threads.
Discussion of sourcing. Now out of date as Splatty is the supplier:
viewtopic.php?f=29&t=9367
viewtopic.php?t=8544
viewtopic.php?t=11496
Potting the near eye display against recoil:
http://nightvisionforumuk.com/viewtopic ... 29&t=11813
viewtopic.php?f=9&t=11889
viewtopic.php?f=29&t=12096
Near Eye Display modding:
viewtopic.php?f=29&t=8556
Rotary brightness switch for near eye display:
viewtopic.php?f=29&t=12337&p=107350#p107350
viewtopic.php?f=9&t=10983
viewtopic.php?f=29&t=9134#p82218
Max voltage for Near Eye Display:
Near Eye Display wiring:
viewtopic.php?f=36&t=13719
viewtopic.php?f=29&t=11991
related:
viewtopic.php?f=29&t=13646
Obtaining extended eye relief on NEDs:
http://nightvisionforumuk.com/viewtopic.php?t=13060
viewtopic.php?f=29&t=13164
Silicone and Near Eye Display ribbons:
viewtopic.php?f=29&t=12352
Near Eye Display adapter plate:
viewtopic.php?f=29&t=10724
modding the NED to permanently on:
viewtopic.php?f=29&t=8972
viewtopic.php?f=29&t=10784
viewtopic.php?f=29&t=10099
Adding brightness and contrast buttons to NED:
viewtopic.php?f=29&t=9735
viewtopic.php?f=29&t=12103
Using the VF2C as a wireless head mounted display:
viewtopic.php?f=29&t=11779
Near Eye displays other than the VF-2C:
Technical discussion of various Near Eye Displays & suppliers:
viewtopic.php?f=3&t=4287
viewtopic.php?f=29&t=5421
VF-2C vs Olightek OLED:
viewtopic.php?f=29&t=11428
Technical discussion of Kopin NED wiring:
viewtopic.php?f=29&t=4025
Technical discussion of OLED NED and supplier:
viewtopic.php?f=29&t=6121
Low resolution 300 x 225 NED from 'Spy Car' kids toy:
viewtopic.php?f=29&t=4529
viewtopic.php?t=5761
Mini Adafruit TFT screen < 320 x 225 NED < VF-2C < OLED display:
viewtopic.php?t=5747
Mini LCD screen vs VF2C:
viewtopic.php?f=29&t=13470
Low res Kopin < Camcorder display<VF-2C
viewtopic.php?f=29&t=5026
LDM 201 small FPV 432 x 240 NED used in Jirka's builds, tested by Splatty:
viewtopic.php?f=29&t=13039
viewtopic.php?f=29&t=11832
viewtopic.php?f=29&t=13718
Discussion of driver boards being specific to each type of NED:
viewtopic.php?f=3&t=3294&start=40
Lens threads:
The simplest solution for a Broom build is to use one of the lenses recommended by Torchwood in his threads. These are Zenit 100mm F1.5 IR M42 mount. Cosmicar 75mm F1.4 C Mount. Samyang F1.4 85mm Canon mount.
Briefly, the best lenses for a Scopeless build are Prime (non telescopic) M42 film lenses or C mount TV lenses.
Varifocal & zoom lenses can be used if there is a lock screw to prevent adjustment. Movement of the lens will change point of impact. CCTV CS & S mount lens are usually cheaply made, with low quality lenses.
Crash course in lenses for Scopeless builds:
http://nightvisionforumuk.com/viewtopic ... 29&t=12513
135mm F2.8 Chinon discussed:
viewtopic.php?f=29&t=9314
135mm M42 lenses and adapters discussed:
viewtopic.php?f=29&t=7345
Samyang 85mm F1.4, Cosmicar 75mm F1.4, Zenit 100m F1.5 discussed:
viewtopic.php?f=16&t=8962
Cosmicar 75mm F1.4 C mount lens discussed:
http://nightvisionforumuk.com/viewtopic.php?f=9&t=13373
Pentax 75mm F1.4 C mount lens discussed:
http://nightvisionforumuk.com/viewtopic ... 29&t=14466
Weights of popular lenses:
http://nightvisionforumuk.com/viewtopic ... 29&t=11646
M42 vs CS. Focal Length vs Magnification. Zoom vs Prime (fixed) lens discussed:
viewtopic.php?f=29&t=4082
SLR lenses discussed:
viewtopic.php?f=29&t=6999
Suitable SLR lenses. F Stop explained:
viewtopic.php?f=29&t=7822
viewtopic.php?t=11778
viewtopic.php?f=3&t=9572#p85671
https://en.wikipedia.org/wiki/F-number
viewtopic.php?f=29&t=7039
Why the 85mm Zenit IR lens is not usable for DIY NV:
viewtopic.php?f=29&t=12248
Why some SLR lens will not hold POA/POI when focused and how to spot them:
viewtopic.php?f=29&t=12365
Ebay 'Fujian' 50mm F1.4 C mount lenses are crap:
viewtopic.php?f=3&t=8070
Effective shooting range of different lenses:
viewtopic.php?t=7963
Estimating magnification:
viewtopic.php?f=29&t=6051
viewtopic.php?f=29&t=7843
viewtopic.php?f=29&t=14019
Jirka's comparison of multiple lens:
viewtopic.php?f=29&t=10199
In depth discussion of spotter lenses:
viewtopic.php?f=29&t=8060
Test of F1.2 & F1.8 12.5-75mm zoom lenses:
http://nightvisionforumuk.com/viewtopic.php?t=10718
F1.4 C Mount vs F1.8 SLR test, cheap CCTV lens discussed.
viewtopic.php?t=9426
Lenses for scopeless - SLR, CCTV or something else?
viewtopic.php?f=3&t=7830
Difference between 50mm and 55mm M42 lens:
viewtopic.php?f=29&t=9721
Cheap CCTV lens under perform when compared to similar M42 & TV lenses.
viewtopic.php?t=9572&start=10
Varifocal lenses for spotters:
viewtopic.php?t=10275
viewtopic.php?t=7517
Use of Yukon NV monocular lens for spotters:
viewtopic.php?f=29&t=11921
Not all M42 lenses are the same quality:
viewtopic.php?t=10203
Use of IR filters to prevent day/night focus shift:
viewtopic.php?f=3&t=14626
viewtopic.php?f=29&t=10454
viewtopic.php?f=29&t=11678
viewtopic.php?f=31&t=14510
viewtopic.php?f=29&t=1397
Discussion of recoil force on Futon, Broom Pro, Photon Extreme & Scopeless lens:
viewtopic.php?f=29&t=12916
viewtopic.php?f=29&t=9357&start=10#p84349
viewtopic.php?f=29&t=8833
viewtopic.php?f=29&t=11780
Alternate lens mount:
viewtopic.php?f=29&t=11887
Note the link in the thread is to a T mount to C mount adapter, this has the wrong thread for an M42 lens. Contact the seller and ask for an M42 to C mount adapter. Or ask SRB Grittuns who provide the Photon Extreme adapters to manufacture one.
Re: Broom Pro Library
Post by phoenix » 14 Feb 2016, 13:05
Radagast,
As always, your librarianship skills are unequalled :thumbup:
gypo
Post by gypo » 14 Feb 2016, 13:12
Nice post, worthy of a sticky id say :thumbup:
G
Torchwood
Post by Torchwood » 14 Feb 2016, 15:34
Nice work there. :thumbup:
Toni
demonfox1
Post by demonfox1 » 15 Feb 2016, 07:53
Very good post indeed :thumbup:
This was my first successful build I learnt to solder making this
Nice one radagast :clap:
Demonfox
Post by some bloke » 15 Feb 2016, 10:14
brilliant wordsmanship there. Is that a word? :wave:
I agree - nay request this be a sticky. :angel:
Locked
