DIY Digital NV In-line Add-on Library
Radagast
junior librarian
Post by Radagast » 17 Feb 2016, 12:36
This thread is a resource for those intending to build an in-line add-on.
Q: What is an In-line Add-on?
A: A clunky name for a digital night vision device that fits behind (add on) a day scope, and uses a Near Eye Display so the shooter appears to be looking through the scope (in-line).
Q) Can I buy one commercially?
A) Yes. But that's not the point of this thread.
Q) But I don't want to build one!
A) Sigh. Look up Ward-D Vision, Nitetek NT300, Starlight Arrow or Night Master Atom. Now go away.
Q) Why would I build one?
A) More compact than the usual digital add on using a TV screen on top of the gun. No screen glare highlighting your face. Interesting and cool thing to do for those into home electronics. Cheaper than a commercial unit. easier to keep a proper chin weld on the stock.
Q) So what do I need to build one?
A)Read the threads below.
Q) Where do I buy the parts?
A) Read the threads below.
Q) I have a different question?
A) If its not answered in the threads below, start a new thread in the DIY NV sub forum.
22-250jock's builds:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=6023
viewtopic.php?f=29&t=9211&start=20
viewtopic.php?f=29&t=2114
http://nightvisionforumuk.com/viewtopic.php?f=29&t=3083
Anthony1973's 3D printed build:
viewtopic.php?f=29&t=14633
Bobc's build:
viewtopic.php?f=29&t=13164
Bullseyeft's build WITH PARTS LIST:
viewtopic.php?f=29&t=14372
Chas' build:
viewtopic.php?f=29&t=1784
Dirt1427's build:
http://nightvisionforumuk.com/viewtopic.php?t=6664
Funkedup's Blue Peter MkII:
viewtopic.php?t=659
funkedup's second build:
viewtopic.php?f=29&t=456&start=60#p4129
Inside the Ward-D Vision:
viewtopic.php?f=3&t=3294
Kahless' build:
http://nightvisionforumuk.com/viewtopic.php?t=13060
Marcos58's build:
viewtopic.php?f=29&t=1057
viewtopic.php?f=29&t=2280
Markusbydark's build:
viewtopic.php?f=29&t=10585
marky610's build:
viewtopic.php?f=29&t=3412
Paul 1961's build:
http://nightvisionforumuk.com/viewtopic.php?t=11805
Paulham's 3D printed housing with PRINTER FILES AND PARTS LIST:
viewtopic.php?f=29&t=14566
https://www.youtube.com/watch?v=hXnQcvJgit8
Pesca's Cobblevision:
viewtopic.php?t=2914&start=40#p28002
Poppy Mae's build:
viewtopic.php?f=29&t=12238
Ptitscarabe52's build:
viewtopic.php?f=29&t=13924&start=10#p120112
Ste2712's build:
viewtopic.php?f=29&t=5659
Sunndog's build:
viewtopic.php?f=29&t=3612
The Griffs build:
viewtopic.php?f=29&t=9394
viewtopic.php?f=29&t=9287
general discussion:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=12930
Near Eye Display discussions:
The Oriscape VF-2C is the best combination of high resolution and low price at this point in time.
The simplest solution for a first time builder is to buy the VF-2C display from UKNVF Trader Splatty that has had the components potted (embedded in resin) to prevent water entry and recoil damage.
In depth info on modding and installation of the VF-2C is in the following threads.
Discussion of sourcing. Now out of date as Splatty is the supplier:
viewtopic.php?f=29&t=9367
viewtopic.php?t=8544
viewtopic.php?t=11496
Potting the near eye display against recoil:
http://nightvisionforumuk.com/viewtopic ... 29&t=11813
viewtopic.php?f=9&t=11889
viewtopic.php?f=29&t=12096
Near Eye Display modding:
viewtopic.php?f=29&t=8556
Rotary brightness switch for near eye display:
viewtopic.php?f=29&t=12337&p=107350#p107350
viewtopic.php?f=9&t=10983
viewtopic.php?f=29&t=9134#p82218
Max voltage for Near Eye Display:
viewtopic.php?f=29&t=13948
Near Eye Display wiring:
viewtopic.php?f=36&t=13719
viewtopic.php?f=29&t=11991
related:
viewtopic.php?f=29&t=13646
Obtaining extended eye relief on NEDs:
Silicone and Near Eye Display ribbons:
viewtopic.php?f=29&t=12352
Near Eye Display adapter plate:
viewtopic.php?f=29&t=10724
modding the NED to permanently on:
viewtopic.php?f=29&t=8972
viewtopic.php?f=29&t=10784
viewtopic.php?f=29&t=10099
Adding brightness and contrast buttons to NED:
viewtopic.php?f=29&t=9735
viewtopic.php?f=29&t=12103
Using the VF2C as a wireless head mounted display:
viewtopic.php?f=29&t=11779
Near Eye displays other than the VF-2C:
Technical discussion of various Near Eye Displays & suppliers:
viewtopic.php?f=3&t=4287
viewtopic.php?f=29&t=5421
VF-2C vs Olightek OLED:
viewtopic.php?f=29&t=11428
Technical discussion of Kopin NED wiring:
viewtopic.php?f=29&t=4025
Technical discussion of OLED NED and supplier:
viewtopic.php?f=29&t=6121
Low resolution 300 x 225 NED from 'Spy Car' kids toy:
viewtopic.php?f=29&t=4529
viewtopic.php?t=5761
Mini Adafruit TFT screen < 320 x 225 NED < VF-2C < OLED display:
viewtopic.php?t=5747
Mini LCD screen vs VF2C:
viewtopic.php?f=29&t=13470
Low res Kopin < Camcorder display<VF-2C
viewtopic.php?f=29&t=5026
small FPV 432 x 240 NED used in Jirka's builds, tested by Splatty:
viewtopic.php?f=29&t=13039
viewtopic.php?f=29&t=11832
viewtopic.php?f=29&t=13718
Discussion of driver boards being specific to each type of NED:
viewtopic.php?f=3&t=3294&start=40
Battery threads:
viewtopic.php?f=29&t=7538
viewtopic.php?f=29&t=14013
viewtopic.php?f=29&t=5694
viewtopic.php?t=9809
DIY battery torpedo:
viewtopic.php?f=29&t=13537
Battery level OSD:
viewtopic.php?f=29&t=10565
Also read the Broom Pro library thread. Much discussion of batteries in there.
Lens talk:
12mm 16mm and 25mm lens images compared:
viewtopic.php?t=3104
viewtopic.php?f=29&t=2019
viewtopic.php?f=29&t=5572
viewtopic.php?f=29&t=11350
Ptitscarabe52
Re: Digital Home brew In-line Add-on Library
Post by Ptitscarabe52 » 17 Feb 2016, 13:58
Thank you very much Radagast.
With the Broom Pro library and this with a lot of informations for us (the Newbies) in night vision... .
Jean Luc
CustomRifleScopesUK
Post by CustomRifleScopesUK » 19 Feb 2016, 00:59
They don't call you the Librarian for nothing :thumbup:
Spewy
Re: DIY Digital NV In-line Add-on Library
Post by Spewy » 17 Oct 2016, 21:11
What is max range of the cl ranger?
Range of the dark night?
Both look perfect looking for 150yard nv inline add on
Stewart
CustomRifleScopesUK
Post by CustomRifleScopesUK » 23 Oct 2016, 21:08
Hi, yes the DL Ranger's limitation at night I found was more to do with the torch that you use, if you only use a T20 then that's the limit,
If you use the other extreme like a laser IR torch, then your range is extended beyond what i would class as safe shooting at night.
The DL ranger has a 12x mag so that would be your ultimate limit to what size target you are shooting at.
The camera i use inside is the ej mini type one so quality is top end.
Splatty
