digital goggles library
Radagast
junior librarian
Post by Radagast » 01 Mar 2016, 13:12
One subject occasionally discussed, but rarely carried through as a DIY build, is the use of video goggles for night vision, either for walking around or as a means of aiming a rifle.
The most well known is probably Rolaids 2.0 build, seen in these videos:
https://www.youtube.com/watch?v=jdb3GMy1wDI
https://www.youtube.com/watch?v=iHeMDBbj6EI
the following links may or may not be of use to a member contemplating a build using video goggles.
Vusix glasses discussed:
viewtopic.php?t=12019
NTSC vs PAL:
viewtopic.php?t=2035
Vusix specs in an old for sale post:
viewtopic.php?t=11120
Rolaids 2.0 Build using Vusix:
viewtopic.php?t=1413
viewtopic.php?t=1455
Other members using the Rolaids build & Vusix:
viewtopic.php?t=3659
S4Fireblade's helmet rig:
viewtopic.php?t=9972
viewtopic.php?f=29&t=10806
DarrenR mentions nausea when using:
viewtopic.php?f=29&t=8644
Binocular / 3D vision discussed:
viewtopic.php?t=6821
Links to different Oriscape goggles:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=6224
Reindeer's Zeiss Cinemizer plus:
viewtopic.php?t=9972#p88939
http://nightvisionforumuk.com/viewtopic ... 10#p112938
viewtopic.php?t=11520
Using the VF2C near eye display as a wireless eyepiece:
Using the VF2C as a wireless head mounted display:
viewtopic.php?f=29&t=11779
Andybig's helmet mounted rig:
viewtopic.php?f=29&t=10163
MrNewbie's build:
viewtopic.php?f=29&t=11783
CBB's DIY IR goggles:
viewtopic.php?t=4512
Torchwood discusses a binocular build:
http://nightvisionforumuk.com/viewtopic ... 29&t=10104
Silk discusses a 3D printed glasses build:
viewtopic.php?f=29&t=12910
Shadowman discusses a build:
viewtopic.php?t=5138
Another build discussion:
viewtopic.php?f=29&t=11520
CJ7Hawke's helmet mount:
viewtopic.php?t=2008
Another build discussion. Why Sense-up is bad:
Discussion of the digital AN PVS14 knock off:
viewtopic.php?t=6175
viewtopic.php?f=29&t=13761
Discussion of digital AN PVS18 build:
FGYT's wireless Vusix add-on:
viewtopic.php?f=29&t=6478
viewtopic.php?f=29&t=6111
viewtopic.php?f=29&t=1029
Wireless camera to screen connection:
viewtopic.php?f=29&t=6302
viewtopic.php?f=29&t=8307
viewtopic.php?t=6111
Skyzone FPV goggles:
viewtopic.php?t=8656
Cyclops Eye FPV goggles:
http://nightvisionforumuk.com/viewtopic ... 29&t=13085
Quantum FPV goggles:
viewtopic.php?f=29&t=13068
viewtopic.php?f=29&t=9210
Cheap Small Near eye Display:
viewtopic.php?f=29&t=13039
viewtopic.php?f=29&t=13718
Modern Warfare toy NV goggles:
viewtopic.php?f=29&t=1815
No name FPV goggles:
viewtopic.php?f=16&t=14256
viewtopic.php?f=29&t=6821
reindeer
Re: digital goggles library
Post by reindeer » 10 Mar 2016, 11:52
Thank you Radagast for this addition to your libraries.
As I said in another thread I have become totally dedicated to the use of Zeiss Cinemizer OLED videoglasses in combination with an e700 add on.
I am extending this build now with an e700 spotter, using a T20 torch head to connect a Yukon 3x42 to the camera as suggested by Poppy Mae.
This spotter build is nearly complete now.
Both e700 cameras from add on and spotter will be plugged in on the Cinemizer simultaniously so that I can choose between spotter signal and add on signal at will. To achieve this the spotter has a push button to operate it and no switch, so that there is no video signal from it when I use the add on video signal to take a shot.
I hope I will be able to post pictures of this complete build later on.
No fence is too tall.......
reindeer
Post by reindeer » 13 Mar 2016, 10:15
I finally found out how to post pictures here, so who is interested in this kind of DIY-NV, Here is my setup, add on combined with spotter and Cinemizer OLED video glasses:
https://www.dropbox.com/home/Cinemizer%20add%20on
Ooops
Post by Ooops » 13 Mar 2016, 12:20
Reindeer I'll be very interested to see how your work with the glasses comes together as I have a set of very basic ones but unsure what to do with them.
I tried the link but get the message "The folder ‘/Cinemizer add on’ doesn’t exist."
I've seen your version of Poppy's Yukon, do you have links for any of your other projects with glasses?
reindeer
Post by reindeer » 13 Mar 2016, 12:25
Hello Jethro
I just tried the link again and on my tablet it does work. It may take a while for the folder to open and show the contents. Please try again and if it does not work I will post pictures again.
Ooops
Post by Ooops » 13 Mar 2016, 13:47
It must be me then 'coz I still can't open it.
In the address it has "https://www.dropbox.com/home......."
I think you can access it because its your box but for the rest of us shouldn't "home" be a user name?
reindeer
Post by reindeer » 13 Mar 2016, 14:39
I think you are right, That is a link to myself.
This one should work:
https://www.dropbox.com/sh/hgeezap0ju7t ... 6UPHa?dl=0
reindeer
Post by reindeer » 13 Mar 2016, 14:45
The Sunnranger in the first picture no longer exists. I mentioned in another thread that imho the difference between regular T20 and Sunnranger is quite evident with S Oslon but much less with AS Oslon, so for now I decided to offer the cut off T20 head and the Yukon lens to my spotter project.
By the way, if anyone would have one or more T20 heads lying around and no use for them, I would like to buy them!
Ooops
Post by Ooops » 13 Mar 2016, 15:56
reindeer wrote:I think you are right, That is a link to myself. This one should work: https://www.dropbox.com/sh/hgeezap0ju7t ... 6UPHa?dl=0
:thumbup: :thumbup: :thumbup: Thanks, all good now
reindeer wrote:By the way, if anyone would have one or more T20 heads lying around and no use for them, I would like to buy them!
:lol: I asked the same question my self in another thread and alas no offers
reindeer wrote:Both e700 cameras from add on and spotter will be plugged in on the Cinemizer simultaniously
So you're semi permanently tethered to the gun and the spotter?
How much more superior do you consider the Cinemizer glasses to be when compared to Vufix?
reindeer
Post by reindeer » 13 Mar 2016, 16:41
Yes, that is the idea. A lot of my night hunting is from high seats. So I can use the spotter to look around. When I see boar I just leave the spotter hanging from a lanyard around my neck, take up my rifle, switch on power to the add on and take a shot. This will also work when sneaking up onto boar when they are feeding on crops and harvested fields, my favourite way of hunting them. That is why I do not want a switch on my spotter. I have no idea what happens when the videoglasses receive signals from both spotter and add on simultaniously and frankly I do not want to try. Maybe one of the more electronically gifted forum members can elaborate here.
As for a comparison between Cinemizer and Vuzix, that depends on the model. VGA resolution, is good, WVGA is better, LED screens are good, OLED screens are better. What model do you have?
Locked
