DIY dedicated digital NV sight with LCD screen (Scopeless) library
Locked
Radagast
junior librarian
Post by Radagast » 05 Mar 2016, 17:51
Scopeless simply means a screened digital NV rifle sight that doesn't require a Day scope.
At the time that UKNV Forum member Some Bloke came up with the first design, all DIY NVs were Add Ons, using a screen on top of a day scope and a camera mounted behind the rear lens. The Scopeless concept kept the screen and camera, but did away with the day scope, substituting a quality camera lens in its place. Hence Scopeless. A better description would be a dedicated digital night vision scope that uses an LCD screen instead of a near eye display.
The following link are intended as a resource and inspiration for those members interested in building their own Scopeless NV sight. Some Bloke continued to develop the idea and sells a number of parts suitable for the DIY builder. He also makes completed Scopeless rifle sights to order. Scroll down past the various home builds to the many threads started by Some Bloke as he designed and manufactured various parts to improve upon the Scopeless idea.
UKNV forum member Rolaids has also developed his own version of Scopeless, the DNVS 3.1. He sells the necessary camera tube / lens mount to USA based members. His builds are linked below, there are links to youtube videos to help understand the concept. Recommended viewing even if another design is chosen.
Pros and cons of Scopeless vs Add On:
viewtopic.php?f=29&t=11185
viewtopic.php?t=8886
One of Some Blokes regular arguments for Scopeless builds is that there is less need for IR illumination compared to Add On rigs. He holds to the view that less IR means less chance of spooking game:
viewtopic.php?f=3&t=9143
viewtopic.php?f=3&t=5156
viewtopic.php?f=29&t=1863
Why bullet cams are better than board cams for Scopeless builds:
viewtopic.php?f=29&t=9184
DIY Scopeless build threads:
Andybig's no machining budget build. Uses Aliexpress / Miracle Cottage bullet cam. INCLUDES PARTS LIST:
viewtopic.php?t=5829
Bones61's build:
viewtopic.php?f=29&t=4853
viewtopic.php?f=29&t=5207
Demonfox1's build:
http://nightvisionforumuk.com/viewtopic ... 29&t=14120
ELLIOT L's build using an E700 camera:
viewtopic.php?f=29&t=7559
Enazle's Frankentein II using Box Camera and Vari-focal lens. INCLUDES PARTS LIST:
viewtopic.php?t=6620
Gypo's build using AliExpress Miracle Cottage Bullet cam and custom camera housing tube:
viewtopic.php?f=29&t=8010
viewtopic.php?t=9938
http://nightvisionforumuk.com/viewtopic.php?f=9&t=7774
Hilbily's Rolaids style build using EJ230 camera:
viewtopic.php?f=29&t=5580&start=10#p53276
Jonnnyfever's Combined screen and viewfinder build:
viewtopic.php?f=29&t=10893
Lenny.sch's very classy side screen build using EJ230 camera:
viewtopic.php?t=2671
viewtopic.php?f=3&t=5209
viewtopic.php?f=29&t=12486&p=113117#p113117
viewtopic.php?f=29&t=4632
viewtopic.php?f=29&t=4443
Lightmesser's build using a Miracle Cottage cam:
viewtopic.php?f=29&t=11382
M_pragnell's build, using an EJ230 camera, based on Rolaids',
viewtopic.php?f=29&t=2397
viewtopic.php?f=37&t=5930
Mallow's build using EJ230 camera in a custom housing, Aliexpress lens:
viewtopic.php?f=29&t=13346
Mechanic775's build, based on Rolaids', INCLUDES AMERICAN PARTS LIST:
viewtopic.php?f=29&t=2388
MrNewbie's build. Side fold screen, board cam in custom housing and battery torpedo:
http://nightvisionforumuk.com/viewtopic ... 29&t=10071
mrNewbie's Just A Silly System V2.0 wireless scopeless:
viewtopic.php?f=29&t=10797
Reaper1064's build based on Some Bloke's parts:
viewtopic.php?t=8005
Rolaids NV3.0 - DIY Digital Scope-less Night Vision :
viewtopic.php?t=1579
Rolaids' Digital Night Vision Scope - Rolaids DNVS 3.1 INCLUDES AMERICAN PARTS LIST:
viewtopic.php?f=29&t=6655
Rolaids' custom built DNVS using varifocal lens:
viewtopic.php?f=29&t=8627
https://www.youtube.com/watch?v=F1KCri37AZ4
S4Fireblade's build:
viewtopic.php?t=10478
viewtopic.php?t=10797#p97815
Smudgerii's mini E700 build:
viewtopic.php?f=29&t=13250
Snapper's build:
viewtopic.php?t=7445
Sverou12's build:
viewtopic.php?f=29&t=13762
Techno's Home Brew "2":
viewtopic.php?t=6697
Terry1001's build, based on Rolaids', using EJ230 camera.
viewtopic.php?f=29&t=3122
viewtopic.php?t=3654#p35588
& using a cheaper cam:
viewtopic.php?t=3200
Torchwood's build using Miracle Cottage Cam WITH PARTS LIST:
viewtopic.php?t=7105
viewtopic.php?t=8429
Torchwood's build with 2.5 inch screen:
viewtopic.php?f=29&t=9003
Torchwood uses two cameras, 1 screen for a combined spotter and Scopeless:
viewtopic.php?f=29&t=8548
Wolf2233's build, WITH PARTS LIST:
viewtopic.php?f=29&t=3070
Some Bloke's Section:
Some Bloke's current design using EJ230 camera:
viewtopic.php?t=10539
viewtopic.php?t=9934
Building the Some Bloke DIY Scopeless Night Vision Sight INCLUDES PARTS LIST:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=7420
Some Bloke's original Scopeless using a Watec camera:
viewtopic.php?f=29&t=1174
viewtopic.php?f=29&t=1863&start=20#p16269
Some Bloke's early board camera build:
viewtopic.php?t=10843
viewtopic.php?f=29&t=8016
Some Blokes early EJ230 camera build:
viewtopic.php?f=29&t=7290
Some Bloke's research thread:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=5790
Some Bloke's EJ230 to C mount carrier tube:
viewtopic.php?t=7421
viewtopic.php?f=29&t=10371&start=30#p92783
Some Bloke will cut back the EJ230 body if ordered from him with his camera housing tube:
Some Bloke discusses range and recoil concerns:
viewtopic.php?f=3&t=8782
Some Bloke tests the Miracle Cottage bullet cam against the Sure 24 EJ230:
viewtopic.php?f=8&t=7078
Some Bloke's E700 camera to M42 lens adapters, more suited to spotters than scopeless:
viewtopic.php?f=9&t=13493
viewtopic.php?f=29&t=13536
Old threads:
http://nightvisionforumuk.com/viewtopic.php?t=10718
http://nightvisionforumuk.com/viewtopic.php?f=9&t=10600
Some Bloke's E700 camera to C mount adapters, more suited to spotters than scopeless:
viewtopic.php?f=9&t=9998
Some Bloke's battery / monitor boxes.
viewtopic.php?f=9&t=10939
Mounting the Some Bloke Scopeless to Weaver mounts:
viewtopic.php?t=10531
Zeroing the Some Bloke Scopeless:
viewtopic.php?f=3&t=9962
Possible recoil induced problems with Scopeless on centerfire:
viewtopic.php?f=29&t=11780
Lens threads:
Briefly, the best lenses for a Scopeless build are Prime (non telescopic) M42 film lenses or C mount TV lenses. Varifocal lenses can be used if there is a lock screw to prevent adjustment. Movement of the lens will change point of impact. CCTV CS & S mount lens are usually cheaply made, with low quality lenses. For the builder who doesn't want to read to far, the Cosmicar F1.4 50mm and 75mm C mount TV lenses are excellent. The Super Takumar 50mm, 55mm and 105mm M42 lenses are good. The Zenit 100mm F1.5 M42 lens is excellent, as is the Samyang 85mm F1.4 Canon lens.
Crash course in lenses for Scopeless builds:
http://nightvisionforumuk.com/viewtopic ... 29&t=12513
135mm F2.8 Chinon discussed:
viewtopic.php?f=29&t=9314
135mm M42 lenses and adapters discussed:
viewtopic.php?f=29&t=7345
Samyang 85mm F1.4, Cosmicar 75mm F1.4, Zenit 100m F1.5 discussed:
viewtopic.php?f=16&t=8962
Cosmicar 75mm F1.4 lens discussed:
http://nightvisionforumuk.com/viewtopic.php?f=9&t=13373
Pentax 75mm F1.4 C mount lens discussed:
http://nightvisionforumuk.com/viewtopic ... 29&t=14466
Weights of popular lenses:
http://nightvisionforumuk.com/viewtopic ... 29&t=11646
M42 vs CS. Focal Length vs Magnification. Zoom vs Prime (fixed) lens discussed:
viewtopic.php?f=29&t=4082
SLR lenses discussed:
viewtopic.php?f=29&t=6999
Suitable SLR lenses. F Stop explained:
viewtopic.php?f=29&t=7822
viewtopic.php?t=11778
viewtopic.php?f=3&t=9572#p85671
https://en.wikipedia.org/wiki/F-number
viewtopic.php?f=29&t=7039
Why the 85mm Zenit IR lens is not usable for DIY NV:
viewtopic.php?f=29&t=12248
Why some SLR lens will not hold POA/POI when focused and how to spot them:
viewtopic.php?f=29&t=12365
Ebay 'Fujian' 50mm F1.4 C mount lenses are crap:
viewtopic.php?f=3&t=8070
Effective shooting range of different lenses:
viewtopic.php?t=7963
Estimating magnification:
viewtopic.php?f=29&t=6051
viewtopic.php?f=29&t=7843
viewtopic.php?f=29&t=14019
Jirka's comparison of multiple lens:
viewtopic.php?f=29&t=10199
In depth discussion of spotter lenses:
viewtopic.php?f=29&t=8060
Test of F1.2 & F1.8 12.5-75mm zoom lenses:
F1.4 C Mount vs F1.8 SLR test, cheap CCTV lens discussed.
viewtopic.php?t=9426
Lenses for scopeless - SLR, CCTV or something else?
viewtopic.php?f=3&t=7830
Difference between 50mm and 55mm M42 lens:
viewtopic.php?f=29&t=9721
Cheap CCTV lens under perform when compared to similar M42 & TV lenses.
viewtopic.php?t=9572&start=10
Varifocal lenses for spotters:
viewtopic.php?t=10275
viewtopic.php?t=7517
Use of Yukon NV monocular lens for spotters:
viewtopic.php?f=29&t=11921
Not all M42 lenses are the same quality:
viewtopic.php?t=10203
Discussion of recoil force on Futon, Broom Pro, Photon Extreme & Scopeless lens:
viewtopic.php?f=3&t=14626
viewtopic.php?f=29&t=12916
viewtopic.php?f=29&t=9357&start=10#p84349
viewtopic.php?f=29&t=8833
Lens adapter threads:
Gypo's camera housing tube for Aliexpress Miracle Cottage bullet camera:
viewtopic.php?t=8622
Also see Some Blokes EJ230 to C mount carrier tube threads.
Also see Rolaids DNVS 3.1 thread for his EJ230 to C mount carrier tube.
Jirka's Universal E700 camera holder/lens adapter, good for project box builds:
viewtopic.php?f=29&t=9858
Using commercial M42 to C mount, C mount to S mount adapters:
Focusing a 135mm M42 lens fitted to C mount adapter, fitted to Some Bloke C mount scopeless tube:
http://nightvisionforumuk.com/viewtopic ... 29&t=12365
Use of IR filters to prevent day/night focus shift:
viewtopic.php?f=29&t=10454
viewtopic.php?f=29&t=11678
viewtopic.php?f=31&t=14510
viewtopic.php?f=29&t=1397
Stronger M42 to C mount adapter:
viewtopic.php?t=11887
Note the link in the thread is to a T mount to C mount adapter, this has the wrong thread for an M42 lens. Contact the seller and ask for an M42 to C mount adapter. Or ask SRB Grittuns who provide the Photon Extreme adapters to manufacture one.
Cutting back the EJ230 camera to fit a CS mount adapter:
viewtopic.php?t=6024
Battery & wiring threads:
18650 batteries, use of, life span:
viewtopic.php?f=29&t=6982
Wiring diagram for screen, IR & camera of same batteries:
viewtopic.php?f=29&t=12661
Interference running IR and screen off same battery:
viewtopic.php?f=29&t=12338
Battery level OSD:
viewtopic.php?f=29&t=10565
Creating Cross Hairs:
Cross hair generator, sold by UKNVF member Igors2255:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=3848
viewtopic.php?f=29&t=2276
viewtopic.php?f=29&t=4102
viewtopic.php?f=29&t=4495
viewtopic.php?f=29&t=13041
Micrio Associates cross hair generator used in Some Blokes Watec build:
https://www.youtube.com/watch?v=OHw79fg ... ature=plcp
Creating cross hairs using the EJ230 privacy mask function:
viewtopic.php?t=7244
viewtopic.php?f=29&t=6087
https://www.youtube.com/watch?v=a2J_lxlN5T4
Creating cross hairs on the Ali Express Miracle Cottage bullet cam:
https://www.youtube.com/watch?v=QqdPzF5tdN0
How to zero the Ali Express Miracle Cottage bullet cam:
viewtopic.php?t=9538
Zeroing with camera based reticles:
viewtopic.php?f=36&t=7227
Privacy zone cross hairs discussed:
viewtopic.php?f=29&t=8492
viewtopic.php?t=4297
viewtopic.php?t=7479
How to fix flipped / mirrored image:
viewtopic.php?f=29&t=4849
Screens discussed:
Use of colored theatre gel filter and computer privacy screens to reduce screen glare:
viewtopic.php?t=8824
Why we recommend Sure24 for screens - a lot of Ebay sellers don't provide the correct item.
viewtopic.php?f=29&t=8706
http://nightvisionforumuk.com/viewtopic ... 29&t=13738
Screen turning off or flickering under recoil:
http://nightvisionforumuk.com/viewtopic ... 29&t=11780
Screen flicker problem:
viewtopic.php?f=29&t=11156
Screen interference caused by torch:
viewtopic.php?f=29&t=10439
Screen dead? Camera must be switched on and video cable plugged in:
viewtopic.php?t=6069
TE968H DVR locks up:
viewtopic.php?f=29&t=2719
Rolaids tests screens and glasses:
viewtopic.php?t=3320
Smart phones & tablets will not work as screens, may work as DVRs:
viewtopic.php?f=29&t=4999
viewtopic.php?t=7158
viewtopic.php?f=29&t=12626
Wireless DVR as screen:
viewtopic.php?f=29&t=7704
http://nightvisionforumuk.com/viewtopic.php?f=29&t=6906
Use of a loupe over screen:
viewtopic.php?f=29&t=9103
viewtopic.php?f=29&t=3120
viewtopic.php?f=29&t=10997
viewtopic.php?t=8113
Locked
