Camera library.
Radagast
junior librarian
Camera library.
Post by Radagast » 11 Mar 2016, 15:11
A compilation of camera discussions over the years. Browsing through here may save the first time DIY builder some money, time and heart ache.
For those who are not interested in in-depth reading, 4 years of camera tests can be summarized as follows:
The Watec 902H was the original standard.
The KT&C E700 board camera is better performing and replaced the Watec in Add-on & Spotter builds.
The KT&C EJ230 bullet camera is the same as the E700 in a different format and replaced the Watec in Scopeless and dedicated night vision sight builds.
The Watec 910HX outperforms the KT&C cameras, but at 8 times the price, so it is not commonly used.
The Watec & KT&C cameras are sold by UKNV Trader member Sure24.
UKNV forum Trader member Splatty sells a smaller bullet cam than the EJ230, for use with his dedicated night vision scope designs.
The Chip set used by the EJ230 & E700 is the 1/3" 960H SONY Exview HAD CCD ll. Other cameras use the same chip set, including several of the AliExpress cameras linked below, but KT&Cs firmware gives their cameras a better result in field tests.
Many cameras use the Sony Super HAD CCD II chip set. These will normally work with IR, but are poor low light performers without illumination.
There are a number of different Watec & KT&C cameras that do not perform well with infra red or in low light conditions. Discussion of those will be found in the threads below.
The above cameras are all of the older CCD type. CMOS is the new standard. To date CMOS cameras that have been tested by forum members did not reach the performance levels of the E700 / EJ230. The CMOS camera in the Yukon Photon XT is an exceptional performer, but to date no one on UKNVF has identified the model or a source for DIY builders.
There are a number of different bullet and board cameras that have been tested and give adequate performance, if not to the level of the KP&C models listed above. Discussion of those will be found in the threads below.
Most camera's come with an IR blocking filter. This will need to be removed for NV work. See threads below. KT&C E700 can be ordered from Sure24 with the filter removed.
Reading the NV101 thread will explain much of the terminology use in the linked threads:
viewtopic.php?f=3&t=6297
Sony camera Chip set terminology and specs is well covered in Wolff2233's stickied post:
viewtopic.php?f=36&t=3503
Camera discussions with link to video comparisons:
Rolaids compares the Watecs, three KT&C cameras and an Ali Express camera:
viewtopic.php?f=29&t=2933
https://www.youtube.com/watch?v=uQ--jL5tks8
viewtopic.php?t=2988
https://www.youtube.com/watch?v=0Q5ZXezirgw
Rolaids compares the KT&C EJ230, DNR230 & E190 cameras:
viewtopic.php?f=29&t=1340&p=11036#p11036
https://www.youtube.com/watch?v=jjIvcOQJYoY
Rolaids in depth review of the KP&C EJ230 and how to adjust settings:
https://www.youtube.com/watch?v=bU4lktH ... e=youtu.be
Some Bloke compares the Watec 902H & KT&C EJ230:
viewtopic.php?f=29&t=6260
https://www.youtube.com/watch?v=VunF9ORbXBA
https://www.youtube.com/watch?v=38k2YVnKCik
Some Bloke compares the KT&C EJ230 and AliExpress Miracle Cottage bullet cam:
viewtopic.php?f=8&t=7078
viewtopic.php?t=7911
viewtopic.php?f=29&t=9467
EJ230:
EJ230 vs Miracle Cottage:
https://www.youtube.com/watch?v=LG_W8hN ... e=youtu.be
Jax13 compares the KT&C E700 and two AliExpress cams. Note that much more IR is used in these tests than in the ones by Rolaids, Marky610 & Some Bloke:
http://nightvisionforumuk.com/viewtopic ... 29&t=13558
AliExpress TopTech Sony Super HAD CCD II Effio-E Bullet Cam:
https://www.youtube.com/watch?v=Sd34c1W ... e=youtu.be
AliExpress TopTech Sony Super HAD CCD II Effio-E Bullet Cam with IR filter removed:
https://www.youtube.com/watch?v=P9pOOWU ... e=youtu.be
Ali Express Boavision Effio E 700 TVL 960 H Bullet Cam from Sub 50 pound build:
https://www.youtube.com/watch?v=8E0eSLT ... e=youtu.be
KP&C E700 camera:
AliExpress TopTech Sony Super HAD CCD II Effio-E Bullet Cam test 2:
https://www.youtube.com/watch?v=oSOj4Ya ... e=youtu.be
KP&C E700 camera test 2 :
https://www.youtube.com/watch?v=MKKm8W9 ... e=youtu.be
Marky610 compares Watec 902H, Watec 902K, Watec board camera & Minitron (mystery mini cam) zoom camera:
viewtopic.php?f=29&t=2493
http://nightvisionforumuk.com/viewtopic ... 29&t=10668
https://www.youtube.com/watch?v=G3XQ5de11Lk
E700 & EJ230 Discussion threads:
Marky610 compares the Watec & KT&C cameras:
viewtopic.php?f=29&t=3179
More Watec vs KT&C discussion:
viewtopic.php?t=2622
Michael40 received one of the first E700 cameras and everyone jumped in discussing it:
viewtopic.php?f=29&t=3975
Marky610 discusses the E700:
viewtopic.php?f=29&t=4061
There are 700 Television Line (TVL) cameras using the Sony Effio E chip set being sold as 'E700' cameras. These are not the KP&C E700 and do not perform the same. Buyer Beware!
viewtopic.php?f=29&t=9867
viewtopic.php?f=29&t=13436
viewtopic.php?t=8060&start=30#p74105
KT&C E700 compared to Ultra Low Starlight Exmor chip set CMOS camera.
viewtopic.php?t=12423
http://nightvisionforumuk.com/viewtopic ... 29&t=10258
viewtopic.php?f=29&t=10904
http://nightvisionforumuk.com/viewtopic ... 29&t=12264
viewtopic.php?f=3&t=11856
viewtopic.php?f=29&t=8731
USA based suppliers for KT&C and Watec cameras:
viewtopic.php?f=29&t=4365&start=30#p42633
viewtopic.php?t=10794
http://nightvisionforumuk.com/viewtopic.php?t=12425
KT&C E700 & EJ230 application threads:
How to set the focus on the E700:
viewtopic.php?f=29&t=13034
viewtopic.php?t=5955
http://nightvisionforumuk.com/viewtopic ... 29&t=12217
viewtopic.php?t=6030
viewtopic.php?t=6738
viewtopic.php?t=8375
How to set the settings on the E700 & EJ230 and what settings to use:
viewtopic.php?t=7673
viewtopic.php?t=10268
viewtopic.php?f=29&t=5689
http://nightvisionforumuk.com/viewtopic.php?f=29&t=5265
How to create cross hairs on the EJ230 & E700 using the privacy masking function:
viewtopic.php?t=7244
https://www.youtube.com/watch?v=a2J_lxlN5T4
Cutting back the EJ230 camera body to fit a CS mount adapter:
http://nightvisionforumuk.com/viewtopic.php?t=12919
viewtopic.php?t=6024
http://nightvisionforumuk.com/viewtopic ... 29&t=10133
UKNVF Trader Some Bloke will cut back the EJ230 camera body if purchased from him with a Scopeless adapter:
viewtopic.php?f=29&t=10371&start=30
http://nightvisionforumuk.com/viewtopic.php?f=29&t=7421
EJ230 cable trimming:
viewtopic.php?t=5858
EJ230 internal wiring:
viewtopic.php?t=7632
How to fit an external joystick to the EJ230:
viewtopic.php?f=29&t=10371&start=40#p101985
Sure24 will sell parts to repair the EJ230:
viewtopic.php?f=29&t=11634
EJ230 joystick cover broken, an easy fix:
viewtopic.php?t=11299
Taking the EJ230 apart:
viewtopic.php?f=29&t=5093
Fitting the EJ230 into a 25mm diameter aluminum tube:
Cutting back the E700 camera housing to suit a CS mount adapter:
viewtopic.php?t=3975&start=90#p51423
viewtopic.php?t=7362
Sure24 will custom mod the cables on the E700 to allow direct plugging into the screen:
viewtopic.php?f=40&t=8830
E700 spare cables:
viewtopic.php?f=3&t=5288
E700 spare box housing:
viewtopic.php?t=6294
Sure24 sell the E700 with the IR filter already removed:
viewtopic.php?f=40&t=6783
E700 housing and lens compatibility. Not all lenses fit the one housing:
viewtopic.php?f=40&t=6412
Adapting the E700 to different lens types:
viewtopic.php?f=29&t=7500&start=10
viewtopic.php?t=9167
viewtopic.php?t=9281
Upgrading the E700 M12 board lens:
viewtopic.php?f=29&t=11556
Jirka's universal holder for E700 camera & M42 or C Mount adapter:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=9858
Jirka is not a Trader member, so contact him via PM or Email for availability.
Kevgun's E700 to C mount holder:
viewtopic.php?f=29&t=13333
Kevgun is not a Trader member, so contact him via PM or Email for availability.
Other KT&C Cameras Discussed:
KT&C A700. Not the same as the E700:
viewtopic.php?t=12754
viewtopic.php?f=29&t=7922
KT&C EX500 for those who want a cheaper camera than the E700. No On Screen Display adjustment for settings. More IR is needed compared to the EJ230, so no real saving in the complete cost of a build. Used in Mini Markyvision / NT120 builds:
viewtopic.php?t=4718
viewtopic.php?t=3975&start=30#p38860
https://www.youtube.com/watch?v=18AhuOBArZs
https://www.youtube.com/watch?v=T-cqVjq4sSs
https://www.youtube.com/watch?v=Mpg2ecYNwtM
KT&C E190: Probably the bullet format version of the KP&C EX500. Used in Rolaids 2.0NV goggles:
viewtopic.php?f=29&t=1413
viewtopic.php?f=29&t=13606
viewtopic.php?t=1455
https://www.youtube.com/watch?v=iHeMDBbj6EI
KT&C EW38 camera, IIRC this was a do not buy, but I cannot find the review thread:
viewtopic.php?f=40&t=5862
viewtopic.php?t=7251
viewtopic.php?f=29&t=7251
KT&C EW230 is not the EJ230. Do not buy.
viewtopic.php?t=7500
KT&C SLL650BH 600 TVL discussed:
viewtopic.php?t=2622&start=30
KT&C E650 750 TVL discussed. Lower performance than the E700, has C/CS lens mount:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=8632
KPC-HD30M:
viewtopic.php?f=29&t=14579
KEZ-C2MIB4:
http://www.Customriflescopes.uk build specific cameras:
Splatty's mini bullet cam discussed:
viewtopic.php?f=29&t=13924
viewtopic.php?f=29&t=13423
http://www.customriflescopes.com/shop.h ... y=13698050
Splatty's EDNV Zoom camera:
viewtopic.php?f=9&t=11582
viewtopic.php?f=29&t=14193
AliExpress / Miracle Cottage cameras.
AliExpress is roughly equivalent to a Chinese version of Ebay. Most of the cameras purchased by UKNVF forum members came from two AliExpress dealers, Miracle Cottage & Macro Snowball, who may be the same people trading under two names. The successful cameras tended to use a version of the 1/3" 960H SONY Exview HAD CCD ll chip set used by the E700 & EJ230.
Interest in these cameras was high due to Rolaids testing one in his watec vs KP&C comparison.
None of the AliExpress cameras beat the KP&C product.
The experience of UKNVF members when ordering from AliExpress wasn't good. Deliveries took up to two months. Some worked well with IR. Some did not. Some were dead on arrival. Or missing parts. Or not as specified. IR filters may not be removed as promised. Warranty may not be honoured. Which is why we don't recommend buying cameras from China. Or lenses. Or Screens. Or batteries. Caveat Emptor.
Miracle Cottage Bullet Cam
Miracle Cottage / Macro Snowball Bullet Cam Model LN-328-9H672/LN-328-9H673:
viewtopic.php?f=29&t=10580#p93478
viewtopic.php?f=29&t=4170&start=100#p99538
viewtopic.php?f=29&t=5803&start=10#p64095
viewtopic.php?f=29&t=10371#p92031
viewtopic.php?f=29&t=9508
viewtopic.php?f=29&t=5610&start=10#p54274
viewtopic.php?f=29&t=7500&start=10#p69836
http://nightvisionforumuk.com/viewtopic ... 5&start=10
Lightmesser feels the quality has been reduced and the product is overpriced:
http://nightvisionforumuk.com/viewtopic.php?t=11382
Some Bloke tests the Miracle Cottage Bullet Cam:
https://www.youtube.com/watch?v=LG_W8hNps10
Miracle Cottage cam with settings adjusted:
https://www.youtube.com/watch?v=9iXcb3W ... e=youtu.be
Miracle Cottage cam - creating cross hairs:
https://www.youtube.com/watch?v=QqdPzF5tdN0
How to zero the Ali Express Miracle Cottage bullet cam:
viewtopic.php?t=9538
Modifying the miracle Cottage / Macro Snowball cam housing to accept CS mount lens:
viewtopic.php?f=29&t=4775&start=90#p48618
Gypo's camera housing tube for Aliexpress Miracle Cottage bullet camera:
http://nightvisionforumuk.com/viewtopic.php?f=9&t=7774
viewtopic.php?t=8622
Gypo is not a Trader member, so contact him via PM or Email for availability.
Other AliExpress Miracle Cottage / Macro Snowball cameras:
Miracle Cottage box cam BN-CL40CB, do not buy:
viewtopic.php?f=29&t=4170#p40287
Miracle Cottage LN300 box cam tested by Rolaids:
viewtopic.php?f=29&t=2514&start=50#p26428
Macro Snowball Model LN300-10633 box camera ordered by Jamez:
LN300-10633 v Watec 902H:
http://www.youtube.com/watch?v=fVhjqyD_0Ss
Macro Snowball board cam Model LN-325-11672 / LN-325-11673 ordered by Andybig:
Miracle Cottage board cam LN-326-8673. No On Screen Display, avoid:
viewtopic.php?f=29&t=4775&start=30#p46457
Macro Snowball Mini cam Model LN-326-11672 / LN-326-11673:
viewtopic.php?f=29&t=4750
Miracle Cottage board cam LN-326-9H672/LN-326-9H673, ordered by Poppy Mae:
viewtopic.php?f=29&t=10580&start=10#p93572
https://www.youtube.com/watch?v=eOSBR7AcavQ
viewtopic.php?f=29&t=10371#p91987
viewtopic.php?t=8198
Miracle Cottage board cam LN-326-9H811 received by M.Pragnell:
Fixing M42 to C mount, C mount to S mount adapters to Miracle Cottage board cam:
viewtopic.php?f=29&t=7500&start=30#p70554
Macro Snowball MCCD box cam Model no. LN-DIY:
Other AliExpress cameras:
CCTV-TOP 700 TVL Effio E Exview HAD II board camera NO OSD:
viewtopic.php?f=29&t=10825
Hongbo Electronics 700 TVL Effio E Exview HAD II board camera OSD:
viewtopic.php?f=29&t=10825&p=95495#p95499
Novoxy Technology Mini Bullet Camera:
viewtopic.php?t=10439
Shenzhen Joint Technology Ltd Exview HAD II dome camera:
viewtopic.php?f=29&t=9097
Shenzhen Joint Technology Ltd Exview HAD II Effio A 800 TVL board camera:
viewtopic.php?f=29&t=14090
Shenzen SDTX SDTX-CCD-C022N / SDTX-CCD-022:
viewtopic.php?f=29&t=4170&start=10#p40304
viewtopic.php?t=5908
Shenzhen Yushida Technology Mini bullet cam from Alibaba. May be the supplier of Splatty's cameras. Link goes to lower spec camera, there are other, higher spec cameras at that site.:
viewtopic.php?f=29&t=5102
Misleading advertising by Shenzhen Unitoptek:
Advertised OSD supported, cable not fitted.
viewtopic.php?f=3&t=6416
AliExpress BoaVision camera used in Jax13's sub 50 pound build. Caveat: The pics are the BoaVision camera. The actual spec in the link is for a Unitoptek camera. Caveat Emptor!:
http://nightvisionforumuk.com/viewtopic ... 29&t=13683
AliExpress TopTech camera used in Jax13's Cheapest night build thread. Caveat: The links goes to the Unitoptek camera spec with the BoaVision pics. Caveat Emptor!:
http://nightvisionforumuk.com/viewtopic ... 29&t=13505
Ebay Super HAD & Super HAD II Cameras:
700TVL Effio-E 1/3" SONY Super HAD CCD II Color Camera Board OSD MENU
viewtopic.php?f=29&t=4255
viewtopic.php?f=36&t=4929
viewtopic.php?f=29&t=10516
http://nightvisionforumuk.com/viewtopic.php?f=29&t=2092
viewtopic.php?f=29&t=5851#p55883
viewtopic.php?f=29&t=6085
http://www.youtube.com/watch?v=ykMleNyA ... e=youtu.be
Starlight 0.001 Lux 650TVL Super HAD II 3D-DNR D-WDR Board Camera with CS Lens:
viewtopic.php?f=29&t=2745
700TVL Sony Super HAD II CCD WDR FPV Board Camera OSD Control Panel
viewtopic.php?f=29&t=8152
viewtopic.php?f=29&t=8016
700TVL 1/3'' SONY 960H Super HAD CCD II Color Board Camera D-WDR with OSD Menu
viewtopic.php?f=29&t=4223
700TVL 1/3 SONY Super HAD CCD Effio-P700 FPV WDR 3D-DNR OSD
viewtopic.php?t=7971
700TVL 1/3" Sony HAD CCD II Color Board Camera
viewtopic.php?f=29&t=1463
viewtopic.php?f=29&t=3698
700 TVL Sony Super HAD with 25mm lens:
viewtopic.php?f=29&t=6942
600 TVL 1/3" Sony Super HAD II box camera:
viewtopic.php?f=29&t=4328
0.0001lux Gen3 CCD Nachtsichtgerät Kamera is a don't buy:
http://nightvisionforumuk.com/viewtopic.php?t=12741
RunCam SKY2 800TVL Super HAD II FPV Camera 1/3'' SONY 960H Effio-V WDR IR Blocked
viewtopic.php?t=10797
CMOS Cameras:
CMOS camera misrepresented as Super HAD. Did not work.
http://nightvisionforumuk.com/viewtopic ... 29&t=13381
Ultra Low Light Starlight Camera 0.00008 Lux 800tvl 1/2 CMOS Sensor:
viewtopic.php?f=29&t=4910
HD 700TVL 1/3" CMOS Video FPV Color Camera:
viewtopic.php?f=29&t=9731
https://www.youtube.com/watch?v=eTiq7IL ... e=youtu.be
520 TVL CMOS camera reviewed by Snoopy:
viewtopic.php?f=29&t=2514&start=10#p24386
viewtopic.php?t=7383#p68798
viewtopic.php?t=9723
viewtopic.php?t=3106#p30225
CMOS IMX139 1/3' board camera reviewed by Weebster
viewtopic.php?f=29&t=11382&start=10
EYEsurv ESIP-PTZ-1080pIR is a don't buy:
viewtopic.php?t=2587
Other cameras:
DHGate Mini night vision Bullet Security Camera Sony CCD RJ10 DSP 650TVL 3D-DNR Starlight 0.0005 low Lux OSD 25mm lens
Genie DN5421 1/2" ExView HAD:
viewtopic.php?t=11394
Lytro camera is a do not buy:
viewtopic.php?f=3&t=10181
Pulsar N550 camera stripped out by Lenny.sch:
viewtopic.php?t=3010
RF Concepts BW Mini 29BSHRX-B36A Low light Sony EXVIEW camera:
viewtopic.php?f=29&t=2514#p23330
https://www.youtube.com/watch?v=WwQBFKSQV0M
RF Concepts low light 1004X BW camera:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=4263
RF Concepts low light 1004XA Exview HAD camera:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=2940
RF Concepts Camera board 1043XA Exview HAD
http://nightvisionforumuk.com/viewtopic ... =10#p32221
Sony CCD Nextchip 2090 camera:
viewtopic.php?f=29&t=8555
Sony Extreme 1/2 inch 600 TVL Exview camera:
viewtopic.php?t=1161
viewtopic.php?f=29&t=2663
viewtopic.php?t=2098&start=10#p19547
viewtopic.php?f=3&t=10331
viewtopic.php?t=1754#p14964
Sony XCE150:
viewtopic.php?f=29&t=1830&p=15707
Stock Optics Super Had II cam:
viewtopic.php?f=3&t=10505
Super Circuits 700 TVL Color Standard Lens Board Camera:
viewtopic.php?f=29&t=6942&start=10#p65489
Surveillance Zone 750 TVL Exview HAD II :
viewtopic.php?f=29&t=8874
viewtopic.php?f=29&t=8198#p74933
Securitycamera2000 threads:
Securitycamera 2000 is a Chinese internet retailer of CCTV cameras. They have been used by a number of members and product was as requested. Seen as cheeky after asking that a forum member buy a camera and then review it for them, where Sure24 provided test cameras for free before deciding if to stock them:
Sony 600 TVL Super HAD Model no.PZ0420 works:
viewtopic.php?f=29&t=10265#p91204
http://youtu.be/66r1tRC9TGE
Sony 700 TVL Exview HAD II Effio S Model no. CML2517X
viewtopic.php?t=3070
viewtopic.php?f=16&t=5000
viewtopic.php?t=3424#p33415
viewtopic.php?t=2513&start=10#p23450
viewtopic.php?t=5555
viewtopic.php?f=31&t=1082&start=10#p9993
viewtopic.php?t=4365&start=10
viewtopic.php?f=29&t=4668
Ward D Vision camera:
viewtopic.php?f=3&t=3294
The Ward D Vision 700 uses the KP&C E700.
Watec Cameras:
Watec Board Cameras were a buy, now superseded by E700:
viewtopic.php?f=29&t=1799
viewtopic.php?t=2046
viewtopic.php?f=29&t=2154
viewtopic.php?t=2357
viewtopic.php?f=29&t=2098
viewtopic.php?f=29&t=2262
Watec 660D discussed:
viewtopic.php?f=29&t=1607
viewtopic.php?t=8158
viewtopic.php?f=29&t=2514#p23468
Watec 902 is a don't buy:
http://nightvisionforumuk.com/viewtopic ... 444#p43083
Watec 902B is a don't buy, Watec 902A is worse:
viewtopic.php?t=3514
viewtopic.php?t=4648
viewtopic.php?t=4937
viewtopic.php?t=9153
http://nightvisionforumuk.com/viewtopic.php?f=29&t=2229
viewtopic.php?f=29&t=2845
viewtopic.php?f=29&t=1963
Watec 902H fixing grainy image:
viewtopic.php?f=29&t=2882
Setting gain on Watec 902H:
viewtopic.php?f=29&t=1734
Modifying the Watec 902H to stop hot spot blooming:
viewtopic.php?f=29&t=1151
http://www.youtube.com/watch?v=eWMsLhQ5PGA&feature=plcp
Micrio Associates cross hair generator used in Some Blokes Watec build:
https://www.youtube.com/watch?v=OHw79fg ... ature=plcp
Lenses for Watec. C Mount adapter for Watec:
viewtopic.php?f=29&t=3013
viewtopic.php?f=29&t=8086
viewtopic.php?f=29&t=2013
12mm 16mm and 25mm lens images compared:
viewtopic.php?f=29&t=1512
viewtopic.php?t=3104
viewtopic.php?f=29&t=2019
Stock Optics variable iris lens vs fixed iris lenses:
viewtopic.php?f=29&t=1676
Watec dead pixels:
viewtopic.php?f=29&t=1275
WAtec running hot + maximum voltage:
viewtopic.php?f=29&t=1500
Watec 902 H2 & 902 H3 Supreme discussed:
viewtopic.php?f=29&t=1353
viewtopic.php?t=3375
viewtopic.php?t=3888
viewtopic.php?t=3431
viewtopic.php?t=3121
viewtopic.php?f=29&t=2620
viewtopic.php?t=2882
Watec 902hs may be OK:
http://nightvisionforumuk.com/viewtopic.php?t=4444
Watec 902 Ultimate discussed:
Watec 902H vs 902 Ultimate:
viewtopic.php?f=29&t=1450
viewtopic.php?f=29&t=1351
http://nightvisionforumuk.com/viewtopic.php?f=29&t=1352
viewtopic.php?f=29&t=1677
Watech 910HX discussed. Great camera, very expensive:
viewtopic.php?f=29&t=3533
viewtopic.php?t=12654
viewtopic.php?f=29&t=8377&start=40
viewtopic.php?t=3420
viewtopic.php?f=29&t=2739
Technical discussions:
Exmor vs Exview cameras:
Issues with unknown Sony board cam:
viewtopic.php?f=29&t=13571
Camera scan rates / shutter speeds explained:
viewtopic.php?f=29&t=13606&start=20
Sony ICXxxx codes explained. Watec vs E700 sensitivity explained.
viewtopic.php?f=29&t=11489
Korean signal processing chip specs:
viewtopic.php?f=29&t=4775&start=30#p46476
viewtopic.php?f=29&t=4170&start=20#p40377
Best sensor / chip set discussed:
viewtopic.php?f=29&t=2516
viewtopic.php?t=11241
viewtopic.php?f=29&t=1753
viewtopic.php?f=29&t=8874#p80079
viewtopic.php?f=29&t=8866
viewtopic.php?f=29&t=7971
viewtopic.php?f=29&t=8087
viewtopic.php?t=7935
viewtopic.php?t=10911
viewtopic.php?t=8060&start=30#p74134
Sens-up long shutter times don't work for gun mounted units, but may help for spotters:
viewtopic.php?f=29&t=1272
Removing IR cut filter glass from in front of Camera CCD:
viewtopic.php?f=29&t=5944
viewtopic.php?f=36&t=6356
viewtopic.php?f=29&t=1089
viewtopic.php?f=29&t=2673
viewtopic.php?t=3502
Using an IR pass filter to cut out visible light:
viewtopic.php?f=3&t=14626
viewtopic.php?f=29&t=1397
Use of IR filters to prevent day/night focus shift:
viewtopic.php?f=29&t=10454
viewtopic.php?f=29&t=11678
viewtopic.php?f=31&t=14510
Digital zoom / magnification of camera image discussed:
viewtopic.php?f=29&t=10668
viewtopic.php?f=29&t=3744
viewtopic.php?f=29&t=4216
viewtopic.php?f=29&t=2572
Privacy zone cross hairs discussed:
viewtopic.php?f=29&t=8492
viewtopic.php?t=4297
viewtopic.php?t=7479
Zeroing with camera based reticles:
viewtopic.php?f=36&t=7227
Camera's with mechanically switched IR filters discussed:
viewtopic.php?f=29&t=10083
How to fix flipped / mirrored image:
viewtopic.php?f=29&t=4849
http://nightvisionforumuk.com/viewtopic ... 3&start=10
Dead camera pixels explained:
viewtopic.php?t=4473&start=10#p43409
viewtopic.php?f=29&t=1353&p=11268#p11268
Incomplete listing.
Re: Camera library.
Post by some bloke » 11 Mar 2016, 16:12
Yer on a roll again Radders. :thumbup:
sam1275
Re: Camera library.
Post by sam1275 » 15 Mar 2016, 20:28
Don't know if it's a bit off-topic...
How does a finished NV product compare to these?
For example, ATN x-sight/supervision compare to e700/902h?
I cannot dind any direct compare...
Re: Camera library.
Post by phoenix » 15 Mar 2016, 22:30
The camera in the X Sight is a full HD (2.1 Megapixel) camera, so it has much higher resolution than the E700/902H which only have around 0.4 -0.6 Megapixels.
That makes the X sight the best digital day scope available for the money and allows it to have a large range of digital zoom without degrading the image seen in the near eye display.
However, having 2.1 million pixels on the same size of sensor as the E700 (1/3) and even worse compared to the 902H (1/2) means that each pixel in the X Sight is much smaller than on the E700 or the 902H.
These small pixels intercept much less light than the larger pixels in the E700 and 902H.
That's not a problem during the day when there's plenty light available, but for NV work where the only source of light is the IR coming from the illuminator, the small pixels simply can't produce a large enough electrical signal to create a decent image.
It doesn't matter how much fancy computing power from the Obsidian core you throw at it, those small pixels are the fundamental failing of the X Sight as a night vision device.
The best commercial digital NV scopes like the Drone pro use sensors with similar resolutions to the E700 and 902H, and because those sensors have much larger pixels they CAN produce large enough electrical signals when the only source of illumination is IR.
Bottom line - any NV product, whether commercial or home brew which uses an E700 or 902H will have better NV performance than an X Sight.
Radagast
junior librarian
Re: Camera library.
Post by Radagast » 15 Mar 2016, 23:04
The CMOS camera in the Photon has larger pixels and will pick up more light. The number of pixels is close to the number of pixels in the 640x480 screen used, so there is no loss in the display. The E700/EJ230 has more, smaller pixels. With a 800x480 display it will have better definition, but the cost is reduced low light performance. It's still better than anything else available for DIY, apart from the Watec 910HX.
I've not looked into the latest Pulsar N870, but I would expect the same or better performance to the Photon, which is made by the same company.
The Drone Pro is noted for needing IR, but giving a very good picture. AFAIK the make of camera installed isn't publicly known.
The ATN X Sight has been a failure, it is now advertised as a day scope with some night time ability, it was supposed to be a night scope with day time ability. It has a large number of pixels, which allows for a high definition daylight picture. The trade off is the pixels are too small for decent light gathering in low light conditions.
Compared to the Night Site NS200 and its ilk, the E700 is much better than the installed camera, one of the earlier DIY uses for the E700 was replacing the NS50 & NS 200 camera.
Radagast
junior librarian
Re: Camera library.
Post by Radagast » 15 Mar 2016, 23:06
Just to add, the Supervision was a failure when it came out, many years ago. There is a long discussion thread on AR15.com about it. Tech has moved on since then. If you must buy a commercial spotter scope then the Pulsar X870 is top of the line, but at a top of the line price.
sam1275
Re: Camera library.
Post by sam1275 » 16 Mar 2016, 09:54
Thank you very much for your answer!
Just one more question please: why all commercial digital NV are high magnification? the lowest is still 2X, why can't they make a 1X with wider field of view?
Re: Camera library.
Post by phoenix » 16 Mar 2016, 12:43
sam1275 wrote:Thank you very much for your answer!
Because at x1 magnification the targets most of us shoot at (rabbits and foxes), and the ranges we typically shoot them at, means they cannot be seen clearly enough to target accurately - in many cases the reticle would completely cover the target
Normal practice is to use a low magnification NV device to spot targets and a higher magnification NV device to to take the shot.
Current best practice is to use a thermal imager for spotting and an NV scope for shooting
sam1275
Re: Camera library.
Post by sam1275 » 16 Mar 2016, 18:01
Thank you very much, but I already know that those scopes are for shooting a far object, I just cannot figure out why all I2T devices have a standard 1X version, while I can't find a single 1X digital night vision?
Radagast
junior librarian
Re: Camera library.
Post by Radagast » 16 Mar 2016, 21:33
Larger lens = more light gathered. This is a stickied archive thread, not a general discussion thread. Please start a new thread for any other questions. If the answers are good enough, then your new thread will be added to the archive.
Locked
