Vfc2 dimmer/variable resistor
bobc
Post by bobc » 04 May 2016, 10:53
Hi guys
Ive searched unsuccessfully for quite a while for a thread where it was discussed about adding a variable resistor/potentiometer to a vf2c screen to dim down the "backlight " if thats the correct term.
Can anyone remember the thread or indeed tell me what size resistor/potentiometer i would need? Also if I remember correctly the backlight has a red and a black wire to it, does it matter which one it goes in ?
Atb
Bob
PhilM
Re: Vfc2 dimmer/variable resistor
Post by PhilM » 05 May 2016, 09:09
Post by phoenix » 05 May 2016, 11:24
bobc wrote:Hi guys
Atb
Bob
Cut the red wire from the driver board to the backlight and solder the cut ends to a 1 kohm potentiometer - job done
bobc
Post by bobc » 05 May 2016, 11:46
Excellent thanks gents
CustomRifleScopesUK
Post by CustomRifleScopesUK » 15 May 2016, 19:50
Hi, i do the pots 1K with switch , so you can control the power and brightness with the same pot switch. making your build neater !
Here is a photo of a diagram i did to help people, i do the smallest 1K pots you can get !
[img]http://i288.photobucket.com/albums ... .png[/img]
hope this helps
Marky610
Post by Marky610 » 15 May 2016, 19:52
2.2k pot works even better
CustomRifleScopesUK
Post by CustomRifleScopesUK » 15 May 2016, 20:16
Marky610 wrote:2.2k pot works even better
Its not just about the Ohms , its also about the taper........you may have got a 1K pot before with the wrong taper and think that the 2.2 has a better dimmer quality. I have tried many and the ones i now have produced from a factory got them spot on for my customers :thumbup:
Splatty
hatsan125sniper
Post by hatsan125sniper » 01 Aug 2018, 21:32
I'm new to all this but he did say something about adding a dimmer to a vfc2 https://youtu.be/zBkjucNVTdI
Post by phoenix » 01 Aug 2018, 22:35
Yes, you can fit a dimmer to the VF-2C, but it's fiddly and easy to break something.
CustomRifleScopesUK
Post by CustomRifleScopesUK » 02 Aug 2018, 13:53
hatsan125sniper wrote:
01 Aug 2018, 21:32
Yes you can add a 1k dimmer switch, i do have a few left in stock if you need one, i also have a drawing so its easy for you to wire into the VF2C
Kind regards CRS
