Homemade nv scope 2
gypo
Re: Homemade nv scope 2
Postby gypo » 20 Nov 2016, 18:15
Nice to see some new blood having a go and coming up with tweeks
Well done :thumbup:
G
reindeer
Postby reindeer » 21 Nov 2016, 15:29
:thumbup:
No fence is too tall.......
Tjensen
Postby Tjensen » 23 Nov 2016, 17:16
Thats a sweet setup!!
What camera and lens are you using?
CustomRifleScopesUK
Postby CustomRifleScopesUK » 29 Nov 2016, 04:44
love the way you have done the snap on screen with power socket......genius :ugeek: :thumbup:
hutty33
Postby hutty33 » 29 Nov 2016, 22:24
Thanks guys.
Tjensen - it's a 50mm fixed focus lens and a bullet cam that has osd with privacy zones, there are loads that will work depending on how much you want to pay and the quality your after :)
Jolyman
Postby Jolyman » 23 Mar 2017, 01:19
Interesting build. Good looking tube.
Looks like you used 30mm Carbon tube? Do you know what wall thickness? I find some 30mm OD X 26mm, 27MM and 28mm ID.
My lens is a 100mm heavy piece and it will go on a .22Mag or .233. Will the 2mm wall (30x26mm) tube be strong enough?
I have never used Carbon fiber. Will normal tools cut and drill it OK? Dremel tools?
How about glue? Does super Glue work? Or some special stuff? :?:
Thanks,
Jim
hutty33
Postby hutty33 » 24 Mar 2017, 00:01
Hi Jim.
It is 30mm OD carbon tube, 28mm ID that I used for this build...sourced on the well known auction site.
I can't say what wall thickness you'd require, nearly everything I do is through trial and error and what you are after isn't something I've tried. However, carbon fibre is a lot stronger than it looks, it may be worth getting a small piece to test for a 'point of failure'.
I only had normal household tools when I made this so I wouldn't say anything special is needed (though some things would make the job easier, the carbon is pretty tough on drill bits and hacksaw blades.)
As for glue, I swear by E6000. I have used it for allsorts over the years and it has never once failed. I did used superglue for some initial building but I just didn't like it.
slimbo1973
Postby slimbo1973 » 24 Mar 2017, 08:02
Very nice build
Shit Shot Stew
andy66
Postby andy66 » 24 Mar 2017, 19:57
Very impressive build :thumbup:
roughcoat
Postby roughcoat » 24 Mar 2017, 20:11
Just to blow your trumpet "Great stuff" mate,cracking ideas :thumbup:
The more I practice the luckier I get
If you venture into maintenance watch out for snakes in the grass
Return to “DIY Nightvision”
Users browsing this forum: No registered users and 21 guests
