Artifacts and recoil question
behoof
Postby behoof » 18 Jun 2017, 16:59
Hi All,
A question... I'm using an EJ230 behind a Cosmicar lens with a 5" video screen... I'm seeing what I might call "artifacts" or little bubble/circle looking things on the video screen... it's not dust or anything inside on the glass... could someone give me some idea of what might be going on? I've also started to see what I would call a few missing pixels on the screen too, I've changed to another screen to see if that made a difference but that didn't change anything...
I'd like to move this setup from my springer pellet rifle to a 6.5 Grendel (recoil feels less than .223) and wondered if anyone has had any experiences they might share regarding this set up?
EJ230 / Cosmicar / 6.5 Grendel
Thanks in advance...
CustomRifleScopesUK
Re: Artifacts and recoil question
Postby CustomRifleScopesUK » 30 Jun 2017, 20:05
Can you record this at all please, that may help us have an idea ?
Kind regards CRS
behoof
Postby behoof » 03 Jul 2017, 15:13
Hi CRS,
Thank you for the reply...
I have no way to record these little artifacts... they look larger than a square pixel on the screen by an order of probably 4x and appear to look like a circle that is just a blemish with a suttle darker edge... they don't stop me from being able to use my gear but if there is something I can do to fix this I'd really like to give it a go...
I've installed various video screens and receive the same result on each so it's got to be the camera... It's an EJ230 with a Cosmicar in front of it... The Cosmicar is as clean as a whistle...
behoof
nealh
Postby nealh » 04 Jul 2017, 03:22
Did you clean the glue from your ccd after IR filter Removal?
behoof
Postby behoof » 04 Jul 2017, 16:10
Yes I did clean ccd and the container spotless before install... I might add that when first installed and completed these little anomalies weren't present, they appeared a couple months after initial assembly...
I used this scope a number of times before these showed up...
CustomRifleScopesUK
Postby CustomRifleScopesUK » 04 Jul 2017, 18:05
Only option is to try another camera !
snoopy
Postby snoopy » 07 Jul 2017, 13:09
are you using a diferrent illuminator or mounting it some where else?
if a diferent cam does the same you may have fungous starting inside the lens..they can be cleaned but quite often its just as well to chuck it..or ebay it.(i.e. thats the pot luck on ebay)
behoof
Postby behoof » 11 Jul 2017, 02:28
Thanks for the replys and advice... Cheers
reindeer
Postby reindeer » 20 Jul 2017, 19:06
What is your power source?
No fence is too high.......
genisis22
Postby genisis22 » 21 Jul 2017, 17:57
dont forget to clean the face of the sensor , and do the artifacts show in daylight no ir if not in day light only with ir clean torch its not a laser ir is it if so that will do it if a new torch check lens for bubbles
Return to “DIY Nightvision”
Users browsing this forum: No registered users and 25 guests
