Homemade nv scope 3
chas
Banned again
Re: Homemade nv scope 3
Post by chas » 04 Feb 2018, 18:40
paulham wrote:Hey hutty, stuck on step 2,
2) Use the lens removal tool to remove the lens retaining ring.
What is a lens removal tool?
Just stick "Lens repair tools" into Ebay and take your pick.
hutty33
Post by hutty33 » 04 Feb 2018, 19:19
One of these mate...there's different styles and fitments -
paulham
Post by paulham » 04 Feb 2018, 20:42
Cheers guys,
Hutty, how are you finding this scope, is it worth doing?
I know you mentioned fogging of the lenses. is it a big issue?
hutty33
Post by hutty33 » 04 Feb 2018, 22:04
paulham wrote:Cheers guys,
I haven't really been out with it recently, and I have dismantled some of it at the moment to check and try some things. On the occasions I've used it, it has worked well...though I haven't fully tested on rimfire yet (and therefore not at ranges over 40-45 yards), but I don't think there'll be an issue.
The fogging - I actually edited the post where I mentioned fogging a little while back...stupidly when it occurred I didn't check to see if it was internal or external fogging, I just assumed internal. The small number of times that I've used it since then have not had any issues with fogging, and testing at home (fridge - warm kitchen - fridge again - and so on) I haven't had an issue yet. I will very likely still purge it just in case.
To answer is it worth doing would be partly down to what you want out of it. It currently gives a better image at night than it does during the day (this is one of the reasons I've took it apart again to try things) but it can still be used in daylight. And I am having second thoughts about the reed switch purely because I haven't used them before and don't know whether it can be fully trusted, I may just fit a switch.
CustomRifleScopesUK
Post by CustomRifleScopesUK » 06 Feb 2018, 21:07
I have a pair of those .......stabbed myself a few times but they are good, get the angle out slightly ones as they get in the corners better !
hutty33
Post by hutty33 » 07 Feb 2018, 17:44
Yep, I've stabbed my fingers, scratched lenses, snapped of bits of the rings...they're not the greatest. The angled ones are definitely better though. You can also get (or make) a different type that is like a 'C' with a handle, and a little pin at the ends of the C, used kind of like a spanner.
rmgcg
Post by rmgcg » 03 Oct 2018, 12:57
Hi!
Can you send me the build instructions? This link (http://www.customriflescopes.com/doityourself3.html) seems to be down.
Thank you
CustomRifleScopesUK
Post by CustomRifleScopesUK » 03 Oct 2018, 13:29
rmgcg wrote:
03 Oct 2018, 12:57
Hi!
Thank you
I assure you it’s not down, here it is again as I’ve just checked
http://www.customriflescopes.com/thebuilds.html
CustomRifleScopesUK
rmgcg wrote:
03 Oct 2018, 12:57
Hi!
Thank you
