New display
tomtom215
Re: New display
Post by tomtom215 » 27 Dec 2017, 10:12
CustomRifleScopesUK
Re: New display
Post by CustomRifleScopesUK » 27 Dec 2017, 11:20
That looks like the power supply to your screen light!
MrNewbie
Re: New display
Post by MrNewbie » 27 Dec 2017, 15:25
On the top picture, you can see the top right ribbon cable goes to the far left of the 3 black pads on the led screen light.
The next break down on the cable goes to the middle black pad on led
The 3rd break, goes to the far right.
The bottom one..the thick one (Ground?..does not matter) goes to all 3 of the bottom connectors on the led.
Looking at the 2nd picture down.. 6 nice little solder pads just waiting for someone to hook wires up.
3 wires to the top 3, and 1 wire to any of the bottom 3..
That's 4 wires on this end..
And very well maybe 4 test points on the other end where the cable plugs in the connector
You need a continuity tester to double ck them
MrNewbie
Re: New display
Post by MrNewbie » 27 Dec 2017, 15:54
tomtom215
Re: New display
Post by tomtom215 » 30 Dec 2017, 09:59
I don´t think I can solder this thing back together :(
Any idea how I could contact about a replacement ribbon cable.
google brought me no results for the number on it
CustomRifleScopesUK
Re: New display
Post by CustomRifleScopesUK » 30 Dec 2017, 12:39
OK GUYS , pre order now and get a cheaper price £60 plus P&P £3.90
Arival date is around the 10th jan
we will be stocking these in as long as people keep ordering :thumbup:
So beat the wait price and import tax and buy from us, knowing if you have a problem, we are here in the UK
this is the unit and its as the picture shows, wires are as follows
3.5v to 5v power supply , can be USB wired
For your camera:
The yellow for video and the black for power.
For our display:
Green is the power positive, white for the power supply negative,
Red and then the video of the positive, gold and video to the ground loop
For signal as below
Signal input:
Green:VCC
Red:CVBS
White:GND
Gold:Signal GND
[img]https://image.ibb.co/bYTAoR/201708 ... .jpg[/img]
lightmesser
Re: New display
Post by lightmesser » 30 Dec 2017, 14:48
I would also order from you but you did not had them at that time...
Could they get this wire combination?
lightmesser
Re: New display
Post by lightmesser » 30 Dec 2017, 15:09
Another question... Look at picture:
Could we just bypass wire from AGN to GND? So AGN(gold as Splatty says) is video ground but ground is ground right? Or not?
If so than we have just one ground wire and less connecting issues...
As you can see in my case red is power, black is ground, white is video and we have naked wire loop(gold) as video ground.
MrNewbie
Re: New display
Post by MrNewbie » 30 Dec 2017, 22:24
Yes, tie em on the inside..or on the outside like in pic
in fact you may not need the AGND wire at all (dont know what it does)..easier to just not hook up or cut than solder
TEST IT FIRST
lightmesser
Re: New display
Post by lightmesser » 31 Dec 2017, 11:44
Thanks Mr. Newbie...
I stepped into eye relief modding:
So game over here? :lol: No... Just new beginning.
Some smaller aspheric lenses I tried at home would work but I am not satisfied with screen size or eye relief after mod. This will need several lenses combination system in order to work not just single aspheric...
It really has yellowish sephia image if I compare it to much cooler VF-2C.
My thoughts so far... This is really high tech stuff with robust driver, robust ribbon cable, robust micro display which is protected with additional acrylic protective film.
Only minus is optics... But I am sure we'll manage to crack that out somehow Image
