Could I run my 12v E700 camera off these batteries?
CroCop
Post by CroCop » 27 Apr 2018, 10:14
Hi.
I am using a V2-FC viewfinder with my DIY setup, and that uses 3 x AAA batteries. Because of this I don't need a big battery, just one to power the camera.
Would these 12v batteries work OK with the E700?
https://www.ebay.co.uk/itm/121578137829
Thanks for any advice :)
Re: Could I run my 12v E700 camera off these batteries?
Post by some bloke » 27 Apr 2018, 11:25
First time I've seen them but can't see any reason they won't do the job.
Not many people realise the SURE24 E700 will run from about 7 volts so you could use one of this type too:
https://www.amazon.co.uk/AmazonBasics-V ... B00MH4QM1S
Benjo3000
Post by Benjo3000 » 30 Apr 2018, 11:58
Those batteries have a capacity of about 55mAh, so would run an add-on for maybe 15-20 minutes, if they can even handle the current draw. They are meant for things like car remotes, and low drain devices.
reindeer
Post by reindeer » 20 May 2018, 07:54
I use 9 v. block batteries from Aldi and they work fine for powering my e700 add on and my e700 spotter.
No fence is too tall.......
snoopy
Post by snoopy » 14 Jul 2018, 11:06
do the maths on the throw aways...
15 sets at a quid is 15
1 set of 18650's x 4 20 quid...lasting for 2-3 years, the 15 quid disposables lasting a month...its a lot.
reindeer
Post by reindeer » 16 Jul 2018, 19:29
I know that 18650 batteries last longer than 9 volt blocks but a set of two is also much bulkier.
Of all the ways that I tried to power an e700 add on, block batteries offer me the best solution when capacity is subject to size.
snoopy
Post by snoopy » 17 Jul 2018, 17:19
sorted there then :thumbup:
