BSP6300 Build?
CustomRifleScopesUK
Re: BSP6300 Build?
Post by CustomRifleScopesUK » 08 Jun 2018, 06:08
Yes I have but make sure you don’t get the potting compound near the sensor or the joystick part for obvious reasons!
Your laser idea on coyotes should be ok but just like I said before, you have a double edge sword. Needing a sensitive camera at night doesn’t make it good when looking at a powerful IR laser........before you go too far with the project, do some testing first, take the camera out with you and the laser and test it on a few animals at different ranges, if it works great but if it doesn’t then you haven’t pulled All the expensive gear apart yet !
Hope this helps crs
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 08 Jun 2018, 20:38
Looking at Zenit lenses on ebay, looks like I can get a working NV-100 for $80. You guys might be turning me into a lens whore...... :lol:
CustomRifleScopesUK
Re: BSP6300 Build?
Post by CustomRifleScopesUK » 08 Jun 2018, 20:59
Well we are all into some sort of Gun porn on here :lolno:
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 12 Jun 2018, 19:41
Any info on this night vision monocular?
The Sharper Image TSI-5500 Artemis 5.5x100mm Night Vision
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 12 Jun 2018, 21:53
It looks like the Firefield 5x50 Nightfall....
Re: BSP6300 Build?
Post by phoenix » 12 Jun 2018, 22:10
I don't see it on their website, so maybe it's an older item that's no longer stocked.
5.5x100 would be pretty unique for a digital NV monocular - the biggest I've seen is 60mm in a Pulsar tubed unit and most of the digital NV monoculars are 50mm or smaller.
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 13 Jun 2018, 18:37
Playing around, 25 yards, just looking at quality and contrast against a white background
I also think I have found a home for my EJ230 The inside of the tube is threaded so you can easily secure a camera with jam nuts and have plenty of adjustments.
CustomRifleScopesUK
Re: BSP6300 Build?
Post by CustomRifleScopesUK » 13 Jun 2018, 19:44
Not sure if anyone else is having the problem, but i cannot see your pictures Joe ?
kind regards CRS
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 13 Jun 2018, 20:45
CustomRifleScopesUK wrote:
13 Jun 2018, 19:44
kind regards CRS
Dammit!!! Half of my electric devices I can see them and the other half I cant. :evil:
JoeDirt
Re: BSP6300 Build?
Post by JoeDirt » 13 Jun 2018, 20:57
13 Jun 2018, 19:44
kind regards CRS
Ok should be fixed I tried a different method..... :thumbup:
