Charging el wire/blue 12v lipo batteries
paulham
Post by paulham » 02 Jun 2018, 11:23
I've lost one of my chargers and need to charge 2 batteries before this evening.
Does anyone know how to charge these el wire/blue 12v lipo batteries?
Can I just supply it 12v from another source or does it need to be controlled?
Paul
paulham
Re: Charging el wire/blue 12v lipo batteries
Post by paulham » 02 Jun 2018, 11:25
Or what about using a splitter to charge 2 at the same time?
Post by phoenix » 02 Jun 2018, 13:27
To get a decent charge into your battery, your power supply should have an output between 12 and 12.6 volts - definitely not more than 12.6 volts.
paulham
Post by paulham » 02 Jun 2018, 16:04
Thanks for the reply Bruce. I was hoping that you would see my thread.
The charger which came with one of the battery packs actually outputs 12.9v. Perhaps this drops down under load.
Paul
Post by phoenix » 02 Jun 2018, 16:35
A proper LiPo charger will have a fixed output voltage, and if it's a 3 cell pack, it will be no more than 12.6v.
If it's just a nominal 12v power supply and it's giving 12.9v off load, then it will probably drop to less than 12.6 when connected to the battery, but you really need a meter to check this.
Also, as the battery charges up and the current going into it gets less, the voltage will rise, and if it's left connected to the charger for too long the voltage may well go above 12.6 and damage the battery.
If you have a voltmeter, try to monitor the battery voltage when the charger is connected and at regular intervals when charging. I'd be incluined to stop charger when the voltage gets around 12.2 volts.
snoopy
Post by snoopy » 14 Jul 2018, 11:10
cheepo B6 hobby chargers or better guys.....at a push yu cant beet having the backup that'll also work on your car battery.
