Convert Lux to V/lux-sec ?
ucanthide
Postby ucanthide » 20 May 2015, 10:30
Does anybody know how to convert Lux to volts/lux-second, and vice versa?
Daniel
Re: Convert Lux to V/lux-sec ?
Postby phoenix » 20 May 2015, 11:43
Daniel,
There's no way to convert lux to volts/lux-second
Lux is measure of visible light INTENSITY
Volts per lux-second is the VOLTAGE produced by a sensor when exposed to light of a given intensity for 1 second.
Sony specify the sensitivity of their ccd and CMOS sensors in millivolts when exposed to a halogen light source of a given intensity.
However they don't specify how much of that light actually falls on the sensor and they also have an IR filter and a f5.6 lens between the light source and the sensor.
Brigates specify the "responsivity" of their sensor in volts/lux-second (Which IMHO is a better way of doing it) but don't provide details of how they actually make the measurement.
Without a lot more detail from the manufacturers (and I doubt they will supply it) then, at present, I don't think there is a way to make comparisons of sensor sensitivity using published data
Only side by side comparison of real cameras gives a true impression of which camera is more sensitive.
ucanthide
Postby ucanthide » 20 May 2015, 12:50
yes this makes sense, makes a mockery of the 'information' they publish on their products really. As you say, the only was is a comparison for real, and this forum, youtube etc.
but based on the information, you think that the higher the V/lux-sec the more sensitive the chip?
Daniel
Postby phoenix » 20 May 2015, 13:24
Daniel,
The higher the volts per lux-second value, the more sensitive the sensor.
The only other way to compare cameras/sensors MIGHT be to compare their signal to noise ratios.
The Brigates sensor may be producing a big signal for the amount of light hitting it, but if the signal is noisy, then it won't be much good for NV purposes.
The BG0601 and BG0301 both claim signal to noise ratios of 48dB
The E700/EJ230 CAMERA claims a signal to noise ratio of greater than 50dB
The Watec 910HX (which is about the best camera out there) claims a signal to noise ratio of greater than 52dB
Even although the dB scale is logarithmic, 2dB is not much
ucanthide
Postby ucanthide » 20 May 2015, 13:52
Bruce,
If we can buy the 13v/lux-sec 1/2'' CMOS sensor with a lux rating of 0.00008 and the S/N ratio is better than the Watec, plus it only costs £32 from the US or £55 in the UK, maybe it sounds a bit too good to be true? But there are about 7 videos on youtube that show it at night time, with both lenses, so we can get some idea of the performance.
https://www.youtube.com/watch?v=qfeg-9U8wLo
https://www.youtube.com/watch?v=9MVMVtRfhbY
https://www.youtube.com/watch?v=00MIMFxkXf4
https://www.youtube.com/watch?v=MPADiBXEA8Q
https://www.youtube.com/watch?v=jyOLOIll0Mc
https://www.youtube.com/watch?v=yUBHiYbfX_E
Plus, the images from the FPV drone footage wont be as good as for a static CCTV application, so Im optimistic it will be excellent for that purpose.
Daniel
ucanthide
Postby ucanthide » 20 May 2015, 13:58
ucanthide
Postby ucanthide » 20 May 2015, 20:35
Bruce,
Tell me what you think about the way this chap explains how camera sensitivity is/should be worked out:
http://www.mintron.com/htm/q&a/htm/mini ... %20lux.htm
Cheers,
Daniel
nealh
Postby nealh » 20 May 2015, 22:25
ucanthide wrote:Bruce,
Daniel
Where in the U S . I'll have a run at it.
ucanthide
Postby ucanthide » 20 May 2015, 22:38
This is the US company, SurveilZone:
http://www.surveilzone.com/0.00008lux-s ... era-cc1564
it works out at £32, but I don't know what postage is or if you might have to pay import duties, VAT etc.
The UK company selling the same camera is tecnic:
http://www.tecnic.co.uk/Ultra-Low-Light ... 00tvl.html
works out at £55.
If you get one I'd be really interested in seeing some videos etc, because when I have the spare cash Im going to buy one.
Daniel
Tommynho
Postby Tommynho » 13 Feb 2018, 14:51
Hello,
Does anybody know, if is it possible recalculate responsivity of image sensor from V/lux*s to e-/lux*s and vice versa?
I would like to know is it better sensor with responsibility 5.48 V/lux−sec or 59 ke−/lux·s
Best Regards, Tomas.
