Commercial Digital In-line Add-on Library
Radagast
junior librarian
Post by Radagast » 26 Feb 2016, 02:59
Q:What is an in-line add-on?
A: a night vision device that fits in front of or behind a normal day scope / telescopic sight, effectively converting it to a night sight.
Q: Are these only digital devices? No. There are traditional 'tubed' and thermal devices as well. This thread is only for links to discussions of digital devices.
Q: Why would I buy one?
A: If you already have a suitable rifle and day scope, it solves the problem of buying another rifle to set up s a dedicated night shooting gun. If you have more than one rifle, most devices can be swapped between them as needed.
Q: Can I make my own?
A: Yes. There is a comprehensive library of home builds stickied in the DIY sub forum.
Pros and cons of front mounted night vision:
viewtopic.php?t=8403
Threads listed by manufacturer.
GB Sights AsPro:
This company is no longer in business, having folded around 2010.
viewtopic.php?t=11766
viewtopic.php?t=1093
viewtopic.php?t=670
Vid: https://youtu.be/KUB06r9MH9I
Ward D Vision:
Also known as Wardy Vision, this comes in two variants, the original and the Ward D Vision 700 using the E700 camera common in home builds. The Ward D Vision uses a prism so the camera is mounted out of line with the scope, making for a relatively short unit. The WDV700 Is currently the best in line unit on the market. Unlike other brands there are very few complaints about performance. The one common complaint is that the manufacturer Clive Ward is hard to contact. A Personal Message through this forum is usually answered promptly, so if he doesn't respond to emails, send him a PM.
http://www.nightvisionstore.co.uk/ward- ... 2x14685612
Inside the WDV:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=3294
Suitable scopes, effective range:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=13226
Suitable scopes:
http://nightvisionforumuk.com/viewtopic.php?t=13723
Suitable scopes:
viewtopic.php?t=12132
Introducing the WDV700. Range, run time:
viewtopic.php?t=8157
Introducing the original WDV:
viewtopic.php?f=3&t=2200
Original WDV review:
viewtopic.php?t=6782
Suitable scopes:
viewtopic.php?t=11507
Compared to Nite-tek add on, Pulsar N550 dedicated scope:
viewtopic.php?t=11564
Compared to the WDV Mini:
viewtopic.php?f=3&t=14255
Suitable scopes, IR torches:
http://nightvisionforumuk.com/viewtopic.php?t=12127
Suitable scopes:
http://nightvisionforumuk.com/viewtopic.php?t=11694
Suitable scopes:
viewtopic.php?t=11672
Comparing WDV & Nite Tek NT300.
viewtopic.php?t=9181
Ability to withstand recoil:
viewtopic.php?t=13307
Compared to Drone Pro, Gen III, NT300:
viewtopic.php?f=3&t=8855
Suitable IR torch:
http://nightvisionforumuk.com/viewtopic ... 31&t=12349
General discussion:
viewtopic.php?f=3&t=5539
General discussion:
viewtopic.php?t=1220
Suitable scopes:
http://nightvisionforumuk.com/viewtopic.php?t=12684
Suitable scopes:
http://nightvisionforumuk.com/viewtopic.php?t=12671
Suitable scopes:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=13723
Suitable scope, IR:
http://nightvisionforumuk.com/viewtopic.php?f=29&t=4409
Videos:
viewtopic.php?t=10334
Fitting a cover to the on/off button:
http://nightvisionforumuk.com/viewtopic.php?t=13248
Ward D Vision Mini.
Cheaper, suitable for air rifle and rimfire ranges, where its larger brother is suitable for centerfire ranges.
http://www.nightvisionstore.co.uk/ward- ... 2x14691760
viewtopic.php?t=5882
viewtopic.php?t=7133
http://nightvisionforumuk.com/viewtopic.php?t=12892
Night Master Atom:
This did not live up to the expectations of forum members. Suitable for air rifle / rimfire ranges.
http://www.taclight.co.uk/products/atom
viewtopic.php?t=13720
viewtopic.php?f=3&t=7927
viewtopic.php?f=3&t=10015
http://nightvisionforumuk.com/viewtopic.php?t=13362
viewtopic.php?t=11637
viewtopic.php?t=11379
Starlight Arrow:
Original unit did not meet expectations. Fitted with the Firefly laser they are fit for purpose. Later upgraded units may be better.
http://www.starlightnv.co.uk/digital_night_vision.html
viewtopic.php?f=3&t=8127
viewtopic.php?t=12618
viewtopic.php?t=5490
viewtopic.php?t=6500
viewtopic.php?t=7556
viewtopic.php?t=6905
viewtopic.php?t=7976
viewtopic.php?t=9136
viewtopic.php?t=7657
viewtopic.php?t=7597
viewtopic.php?t=9766
viewtopic.php?f=3&t=8988
viewtopic.php?t=12323
viewtopic.php?t=5742
viewtopic.php?t=11343
Nite-Tek NT300 & Nite-Tek NT120:
Produced by NVFUK member Marky610, the king of the home builders. Equal performance to the Ward D Vision 700 or Mini, in a slightly longer body. Cheaper too. No longer produced.
Vid: https://www.youtube.com/watch?v=BgMzPji ... ploademail
viewtopic.php?t=5968
viewtopic.php?t=6247
http://nightvisionforumuk.com/viewtopic.php?t=13468
viewtopic.php?t=5681
viewtopic.php?t=5220
viewtopic.php?t=5354
viewtopic.php?t=8657
NVUK.CO.OK Artemis:
viewtopic.php?f=3&t=14238
Lardy Vision:
This was developed by Darren Rodgers/Lord Lard of Rams, with input from Marky610. It can be considered the prototype to the Ward D Vision:
http://nightvisionforumuk.com/viewtopic.php?t=12955
viewtopic.php?t=4942
viewtopic.php?t=1022
viewtopic.php?f=29&t=1567
Armasight Cipher:
A front mounted digital add on. Not yet available:
viewtopic.php?t=10875
Genesys Remora:
Rear mounted digital add on. Not yet available.
Pulsar DFA75:
Front mounted digital add on. First version replaced free of charge with second version. Zeroing and holding zero problems. Many unhappy buyers.
viewtopic.php?f=3&t=1527
http://nightvisionforumuk.com/viewtopic.php?t=13629
viewtopic.php?t=7413
viewtopic.php?f=3&t=1135
viewtopic.php?t=4894
viewtopic.php?f=16&t=8490
viewtopic.php?t=2835
viewtopic.php?t=2892
General discussion:
http://nightvisionforumuk.com/viewtopic.php?f=3&t=12930
Incomplete listing.
Re: Commercial Digital In-line Add-on Library
Post by some bloke » 26 Feb 2016, 04:48
Still earning ya keep there Radders. :thumbup:
