Pvs14
Bobbyboy
Pvs14
Postby Bobbyboy » 12 Jan 2018, 01:03
Hi guys bit of info needed can I use my pvs14 on my 22.250 been doing a bit of home work on line but coming up with some saying yes and some saying no are any of you guys using one on a 22.250 please comment advise will be appreciated thanks bob
Re: Pvs14
Postby warbucks » 12 Jan 2018, 03:42
The Pinnacle/autogated tubed one is only rated to 223, think all the other tube options are rated higher, so you need one thats not pinnacle/autogated.
Bobbyboy
Re: Pvs14
Postby Bobbyboy » 12 Jan 2018, 06:16
Mines defo auto gated itt tube MFR 13567 F8915DTN
So that would be a no go then cheers bob
Radagast
junior librarian
Re: Pvs14
Postby Radagast » 12 Jan 2018, 12:22
F9815WG is the weapons grade tube. You have an expensive piece of kit, so don't risk it.
http://aunv.blackice.com.au/forum?index ... story=omni
camo304
Re: Pvs14
Postby camo304 » 12 Jan 2018, 15:17
Have a look at this post from David.
It's a complicated question. The .243 is right in the danger zone. My recommendation would be Gen2 or non-gated Gen3 with a halo size well above 1.0mm
I don't post this much here because in the UK there's not a lot of Gen3 and not a lot of use of larger calibers.
G/s around 300 or less = Usually OK. 400 = precautions as above. 500+ = DO NOT USE without recoil mitigating housing.
It's not an absolute list - just a guideline to help with NV selection Vs Cartridge selection. It's based on a 4Kg rifle ( US AR15 ) so take that into account also. Only fixed rifle weight counts. But it helps put peak recoil in perspective.
Regards
David
( I have the full table available if anyone wants it - this is just cartridge and peak recoil in G's - Note, Moderators and muzzle brakes will not have any effect on the below calculations )
Cartridge G's
.17 Hornet 174
.17 Mach 4 197
.17 Rem 203
.204 Ruger 278
.22 Short 115
.22 Long 132
.22 LR 132
.22 WMRF 132
5.6x35R 215
.22 Hornet 241
.218 Bee 248
.22 Rem Jet 220
.221 Rem 288
5.6x50R 270
0.222 302
.222 Mag. 333
0.223 350
.219 Zip. 223
.225 Win. 327
.22-250 357
.220 Swift 340
.223 WSSM 367
5.6x61R v.H. 303
5.6x52R 265
.22 Sav. 263
6x70R 240
6x50R 405
6x52R Bret. 304
.243 WSSM 435
.243 Win. 402
6 Rem. 411
.240 Wea. 418
6x62 392
6x62R 392
.240 Fl.NE 300
.25-20 276
.25-20 S.S. 156
.256 Win. 379
.25-36 Marlin 220
.25-35 312
.25 Rem. 255
.250 Sav. 376
.257 Rob. 404
.25-06 447
.257 Wea 479
6.5x52R 267
6.5 Jap. 319
6.5x50R 394
6.5x70R 304
6.5x52 Car. 304
6.5x53R 342
6.5x54 M-S 394
6.5x54 Mauser 327
.260 Rem 460
6.5x55 408
6.5x58R 304
6.5x57 423
6.5x58 Mauser 379
6.5x57R 356
6.5x72R 408
6.5 Rem Mag 468
.264 Win Mag 506
6.8 SPC 480
0.27 537
.270 WSM 537
.270 Wea 529
7x50R 456
7-30 Wat. 422
7x72R 353
7-Aug 525
7x57 491
7x57R 422
7 Fl.Mag. 413
7x65R 474
7x75R v.H. 517
.284 Win 585
.280 Rem 533
7 WSM 560
7 Rem Mag 534
7 Wea 551
.280 Fl.NE 382
.30 Carb. 469
.30-357 AeT 449
.30 Rem AR 561
300 Blackout 561
.30-30 469
.30 Rem 418
.303 Sav 406
.300 Sav 541
.308 Marlin 506
.30 Fl.Purdey 469
.30-40 480
.307 Win 641
.308 Win 667
.30-06 602
.30 R Blaser 602
.300 Whisper 405
.300 Whisper HP 506
.300 WSM 663
.300 H&H 633
.300 Win 653
.30 Fl.Mag. 469
.300 Wea 663
.300 RUM 663
.300 Lap.Mag. 694
.303 Brit 552
7.62x39 526
7.62x54R 582
.32-20 348
8x72R 461
.32-40 395
.32 Spl. 488
.32 Rem 499
8x50R 574
8 Lebel 574
8x57 JRS 540
8x57 JS 641
8x60RS 551
8x64S 664
8x65RS 664
8x75RS 619
8 Rem Mag 754
0.318 550
.333 Riml.NE 604
.338 Fed 803
.338 Marlin 596
.33 WCF 543
.338-06 A-Sq. 842
.338 Win 829
.338 RUM 842
0.348 632
.351 Win SL 42
9 Luger 498
9x57 584
9x57R 584
.38 Spl 360
.357 Mag 650
.357 Max 694
400/350 744
.350 No.2 667
.350 Mag Rigby 625
.35 Rem 556
.35 WCF 611
.356 Win 862
.358 Win 857
.350 Rem Mag 861
.35 Whelen 806
9x53R 698
.360 NE 2¼ 529
9.3x72R 441
9.3x57 654
9.3x62 867
9.3x64 973
9.3x74R 745
9.3x65R 836
.375 Win 1021
.375 NE 2½ 510
9.5x57 M-S 698
.376 Steyr 994
.375 H&H 989
.375 Wea 1021
.375 Fl.Mag. 749
.369 NE 679
.378 Wea 1037
.38-55 573
.38-40 278
.40-82 Win 435
.41 Rem Mag 839
.400 Jef. 744
450/400 3¼ 987
.400 H&H 1161
.405 WCF 670
.416 Rem. 1276
.416 Rigby 922
.404 Jef. 981
.44-40 351
.44 Spl 351
.44 Rem Mag 900
0.444 1140
.45 ACP 482
.45 Colt 367
.454 Casull 1332
.45-70 666
.450 Mar 964
.458 SOCOM 833
.458 Win. 1475
.458 Lott 1475
.450 NE 3¼ 1010
.450 No.2 NE 941
.465 Belted 1520
500/465 1021
.480 Ruger 1254
.475 Linebaugh 1279
.475 Turnbull 1075
.470 NE 977
.475 No.2 NE 1023
.505 Gibbs 1128
.500 Jef. 1361
.500 NE 3" 1162
.50 BMG 1531
.50 BEOWULF 936
.577 3" NE 1359
.600 NE 1470
.700 NE 2223
4 Bore Rifle 4082
Bobbyboy
Re: Pvs14
Postby Bobbyboy » 12 Jan 2018, 21:14
It's a night mere lol I might just flog this unit and get anther archer to be honist less agrow my last one I had I chuck it on all sorts and never had a problem at all
Cheers bob
Bobbyboy
Re: Pvs14
Postby Bobbyboy » 12 Jan 2018, 22:54
Mines a weapon grade tube as the guy says above 1.25 halo 223 rating is 3.50 my 22.250 is 3.57 so not a lot in it but if you take into consideration mine is a remme700 vssf the rifle wieght is over 11lb rigged as it has the heavy stainless barrel the the recoil of my rifle is less than the standard 223 so in reality I should be fine
Users browsing this forum: No registered users and 22 guests
