Ward 800L
robindrury
Ward 800L
Postby robindrury » 08 Feb 2018, 10:51
Hi all I have a ward 800l with a nm800 ruby pill I'm using a delta titanium scope is there a way to avoid the white out that appears when zooming in
cheers robin
Re: Ward 800L
Postby some bloke » 08 Feb 2018, 11:32
Consider using less light by turning the IR power level down and aiming the tight beam higher into the distance so it doesnt swamp the foreground. :idea:
Re: Ward 800L
Postby warbucks » 08 Feb 2018, 15:46
Hi Robin.
Go to the illumination section, diy illumination "stickies" post here, topics, passing on some tips by Marky 610, this will explain how best to set the illumination up for all add on systems.
If your only getting the "white out on higher mag, then that is an indication it is stray light spill---------unlees your running the illumination on a wide -ish spread, you shouldnt really be having this problem with the Wardy, as its very forgiving with excess illumination, nearly always use my wardy 700 with full power T74 bs2 even with 40 yd rabbits usually without a problem.
robindrury
Re: Ward 800L
Postby robindrury » 09 Feb 2018, 16:51
Thanks for the advice will try out as soon as I can
