.22 hornet & ammunition
micky2506
Post by micky2506 » 04 Sep 2017, 20:28
Hi people what ammunition in factory loads do you use in you're .22 hornet. I have a .22 hornet cz 527 American I've tried different loads a few of them jam up in breach which is annoying it also scores the head on the bullet .any decent info will be much appreciated
Re: .22 hornet & ammunition
Post by phoenix » 04 Sep 2017, 20:44
PPU 45gn is the cheapest
Hornady 35gn V max is excellent, but a lot more expensive.
I've had problems with rounds not extracting from my Weihrauch hornet, but a thorough clean of the chamber with a brass bristle brush on the end of an electric drill seems to have sorted the problem
Post by cliveward » 06 Sep 2017, 12:42
micky2506 wrote:Hi people what ammunition in factory loads do you use in you're .22 hornet. I have a .22 hornet cz 527 American I've tried different loads a few of them jam up in breach which is annoying it also scores the head on the bullet .any decent info will be much appreciated
Is it only scoring once a round has been chambered or is it from the bolt running over the top of rounds in the magazine?
micky2506
Post by micky2506 » 06 Sep 2017, 18:46
It seems to score the bullet head if it's not gone straight in to the chamber .it's sometimes gets jammed that's when it seems to happen .I've tried various bullets some are worse than others it's a cz 527 American .the gun was new when I bought it
Post by cliveward » 07 Sep 2017, 10:04
micky2506 wrote:It seems to score the bullet head if it's not gone straight in to the chamber .it's sometimes gets jammed that's when it seems to happen .I've tried various bullets some are worse than others it's a cz 527 American .the gun was new when I bought it
It sounds like it's not feeding properly.
Are you able to try it with a different magazine? Perhaps take it back to the shop and see what they say.
njc110381
Post by njc110381 » 08 Sep 2017, 12:04
My 527 used to feed flawlessly with every type of ammo I fed it. It sounds to me like it needs to go back to the RFD to be checked. It could be (probably is) the magazine not lining the round up with the bolt properly.
micky2506
Post by micky2506 » 08 Sep 2017, 17:34
Thanks for you're reply any help is much appreciated
quickie
Post by quickie » 30 Nov 2017, 10:33
my jaggmach 22 hornet was having the same broblem . sent for a new extractor no problems the tip had broken off
Mini Magnum
Post by Mini Magnum » 30 Nov 2017, 14:29
Another Hornet user here, getting amazing results using 40gr vmax over 12.7gr lil gun.
