Calibre question?
Re: Calibre question?
Post by phoenix » 10 Oct 2017, 21:04
I agree that not all the powder is burned in a 20" barrel and (because it's only used at night) flames are visible when the rifle is fired.
24 or 25 inches might be a good barrel length for a 22-250 if you're on the range or are in a high seat, but try to use a rifle with a 24 or 25 inch barrel with a sound moderator on the end of it when shooting from inside a vehicle and you'll soon realise that a short barrel does have it's advantages.
With 42gn of RS60 powder and a 50gn VMax bullet, the muzzle velocity from my 20" barrel Tikka T3 22-250 is 3800 ft/sec (1157m/s) and a muzzle energy of 1650 ftlbs (2237 joules) - which is more than enough for any fox.
In darkness, and using a thermal spotter to detect foxes and a thermal riflescope to shoot them, the biggest problem is range estimation - you can't easily use a laser rangefinder in the dark.
Therefore I use a calibre that (within reason) fires a bullet with the flattest trajectory possible , and which is heavy enough to ensure a clean kill.
Both 222 and 223 are perfectly good calibres for shooting foxes, but at extended ranges their bullets drop more than a 22-250 making it necessary to apply some "Arkansas Elevation"
As for the 22-250 and 243 being "barrel killers" - that depends rather more on the rate of fire rather than actual number of rounds being fired.
Each round fired puts a certain amount of heat into the barrel and between shots, the barrel loses heat to it's surroundings.
If shots are fired at a rate such that the heat going into barrel exceeds the rate at which heat can leave the barrel, then the barrel can overheat and be damaged
if I go to the range and fire 50 rounds in an hour, and do that regularly, then there's a good chance that the barrel life will be short.
But if I'm out shooting foxes and fire 3 or 4 rounds in a session lasting 4 or 5 hours, then the barrel life will not be compromised.
Wild-Boar
Post by Wild-Boar » 10 Oct 2017, 22:22
It is possible to make a privacy masking reticle like the russian scope https://upload.wikimedia.org/wikipedia/ ... e_meas.png for foxes.
I agree that short barrels are easier to handle.
Thats right too. But today you can use brass bullets and have the same result with more moderate cartridges. For example this 223 http://lutzmoeller.net/1/5,6-mm/223-Rem.php something around 4 inch drop at 300 yards!
Stefan
Sussexsteve
Post by Sussexsteve » 14 Nov 2017, 01:13
I shoot 204 and 243. Shot 100s with 223 and 22-250. All do the job if the bullets put in the right place. Don’t get runners. Dropped every fox I’ve shot with the 204 out to 330m with thermal scope.
Tikka222
Post by Tikka222 » 16 Nov 2017, 14:56
I use 222 and 243 both have mods 243 deff the better caliber with mod you here the strike and there are no runners
Toddy
Frogman Ladue
Post by Frogman Ladue » 03 Dec 2017, 01:19
Has "the market" (over there) start feeding you guys on 22 Nosler, or 22 Wylde/.223 Wylde, or 224 Valkrye yet? Guys are going nuts over here to drop .223 like a bad habit.
