Need recommendations on a scope.
Frogman Ladue
Post by Frogman Ladue » 04 Oct 2017, 20:21
I need recommendations on a scope. I figured I'd ask you guys, as the Murican consensus is limited to two scopes.
I'm looking to scope a .357magnum bolt action...I don't need big magnifications, or the best glass - this will be a 150m gun at tops. Rings are limited to 1". My budget is around 300 quid. It's going to be a hunting/field gun. Bushwhacking, rain/snow, drops, and long trips on gravel roads tied to the front end of an ATV will happen. I need durability. I prefer capped, re-zero'able, turrets that don't require tools to adjust.
I don't need AO or side focus. I don't need illumination.
Thoughts.
Re: Need recommendations on a scope.
Post by phoenix » 04 Oct 2017, 21:29
Vortex Diamondback 4-12x40
Athlon Argos 3-15x40
Sightron SIH-TAC 4-12x40
Nikon Prostaff 3-9x50
Leupold
Bushnell
Burris
Redfield
£300 ($400) will get you a lot more in the USA than it would here, so you could possibly move up a grade from the scopes I've listed
Wild-Boar
Post by Wild-Boar » 09 Oct 2017, 20:51
Hi
this is my first post here. Try to find a old Kahles Helia Super in steel. They are still the favorite scopes in the austrian mountains.
Post by sunndog » 09 Oct 2017, 20:56
Wild-Boar wrote:Hi
Try starting a 'wanted' thread in the sales section fella
oslon black drivers
Frogman Ladue
Post by Frogman Ladue » 13 Oct 2017, 00:14
Wild-Boar wrote:Hi
Thanks, someone with a real recommendation. Kahles are a little above my 300 quid, $450 budget. It's only a .357 mag shooting 150m tops. I'll never be able to use a Kahles to its full potential in that setting.
Wild-Boar
Post by Wild-Boar » 13 Oct 2017, 09:16
Hi
maybe you can find one here http://www.egun.de/ postage with DHL shouldnt be to expensive.
here is one example http://www.egun.de/market/item.php?id=6632119, but you will find cheaper ones.
cheers
stefan
