Moderator options for .22WMR
gunnybedford
Post by gunnybedford » 28 Jan 2018, 18:40
Hi
I am awaiting the return of my FAC, which has been varied to add .22WMR for foxing, I am getting a mini mauser action .22WMR which has not been screw cut, this is a bit of a problem as my main permission is within a village, fine with my moderated .22 shooting subs, but the supersonic crack of the WMR might be a tad noisy in the middle of the night.
So first question is, can any one recommend somebody who is capable of doing a good job screw cutting in the Kent area ? ( I live near Hythe)
Secondly what are my options with some form of adaptor that would mount onto the end of the barrel ? ive seen a parker hale adaptor which fits barrels between 13.5 mm and 16mm (not sure what the barrel of my WMR is yet) but having read one description a bit unsure as this description stated it was only to be used with air rifles ? are there any decent adaptors for rimfire ?
or are there any good moderators that can just clamp onto a barrel ?
thanks
Neil
Spanner
Re: Moderator options for .22WMR
Post by Spanner » 28 Jan 2018, 19:26
You need to get it screw cut if its long I would shorten to 18 inches whilst you are at it, I have just put a Wildcat Panther on my 17 Hornet it is compact and does a great job.
Post by cliveward » 28 Jan 2018, 20:28
Hi Neil,
I would drop into Ashford Gun Room and look at the Wildcat Panther. They may also know someone who can thread your barrel for you.
Unfortunately the two excellent Gunsmiths I could recommend in Kent have sadly passed away.
If Ashford Gun Room can't help then perhaps get in touch with Dane & Co. http://www.customrifle.co.uk/index.html
Cottis
Post by Cottis » 28 Jan 2018, 20:48
Another vote for the Wildcat Panther. Awesome on my .17 and being honest pound for pound it is better than my CF mods.
gunnybedford
Post by gunnybedford » 28 Jan 2018, 21:38
thanks Clive, was planning on going over there tomorrow ! by chance is one of those gunsmiths a certain Mr Roper ? I ask as i used to know him, - I shoot with Cinque port rifle club.
regards
Neil
gunnybedford
Post by gunnybedford » 29 Jan 2018, 16:49
For those in the Kent area, i was referred to company in Ashford called Morse engineering, it was suggested at the Ashford Gun room that they had screw cut a number of rifle barrels. I gave them a ring today and they confirmed they could do it, they are a CNC machining and engineering company, so hopefully will be capable of doing a good job ! i will be taking the .22 WMR over there to get sorted.
scirroco
Post by scirroco » 05 Feb 2018, 17:53
You also have paddy dane in kent ,a custom.riflesmith,
Search for dane and co
Rgds steve
