which scope to buy
lanerboy
which scope to buy
Post by lanerboy » 10 Feb 2018, 14:45
Hi All
I am after a scope for my 22lr I would like something like 4-16 x 50 with adjustable parallex I had a hawke on my last rimfire with adjustable parallex but I cant remember the model but I was very happy with it. What would you buy am looking at spending sub £150 on a decent 2nd hand scope.
Also what do you think of the quality difference between Hawke and Nikko Sterling I don't know which is best its just my local gun shop sell these brands if I cannot find a decent conditioned 2nd hand unit.
Also would be looking at fitting a nv add on set up to it on occasions for night ratting sessions.
LB
Re: which scope to buy
Post by some bloke » 10 Feb 2018, 15:05
If ratting is on the agenda I'd have one that starts at 3 mag rather than 4 if you can, especially if only a few feet away for a wider field of view. You'll not be needing more than 9 mag for bunny bashing so a 3-9 would be better than a 4-12 in my opinion.
Hawke and MTC both give good results - as do Nicco Sterling apparently but I've not personally used one.
lanerboy
Post by lanerboy » 10 Feb 2018, 15:08
I need it for all sorts will do some ratting but not loads mainly rabbits with the 22lr
My local gunshop have this on offer at £195
HAWKE PANORAMA 6-18×50 AO
Thoughts please
Post by some bloke » 10 Feb 2018, 15:40
6 starting mag is way too high even for occasional ratting
lanerboy
Post by lanerboy » 10 Feb 2018, 15:47
I have a hawke 3-9 x 50 night eye scope so I could use this when ratting on my hw 100 so may do that
Still leaves me with what to use on the rimfire ??????
Post by some bloke » 10 Feb 2018, 15:51
I don't think they have parallax? See where the focus is when the NV is fitted before replacing it - it'll likely focus closer wi Infra Red light.
sauer
Post by sauer » 20 Feb 2018, 21:59
Contact fox firearms, look at their site ... they do 4x16x50 I think for around £100,or less and for the money they are brilliant.... folk using them for long range gongs & they dial well ... lot of scope for money ... & side paralex too
Paul
