Firing pin spring
gunnybedford
Firing pin spring
Post by gunnybedford » 18 Jun 2018, 19:49
So the saga with my Mauser .22WMR continues ! need a new firing pin spring, Mauser cannot supply them, and the company i found in Germany do not have any !!
Does anyone, anywhere have any idea where:
a. I could possibly get hold of a Mauser spring ?
b. Know of anyone who is capable (and bothered) to manufacture a spring that would suffice.
Neil
fizzbangwhallop
Re: Firing pin spring
Post by fizzbangwhallop » 19 Jun 2018, 07:17
Could try J&P springs in the us? They sell upgraded springs for rimfire.....worth an email at least, I think the P is Pete, he’s been helpful in the past.
https://www.jnpgunsprings.com/
Or it sounds like the sort of thing that Dave at Valkyrie might be abl to help with.... he’s Baldy on the uk varminting forum.
8-)
Post by cliveward » 19 Jun 2018, 10:11
Hi Neil,
Have a look here:
http://www.flexosprings.com/stock-sprin ... on-springs
Just measure OD of the spring, length, number of coils and wire diameter and you should get pretty close.
If not they do custom springs, as do a company called Lee Springs.
Failing that a decent gunsmith should be able to make you one. :thumbup:
bavarianbrit
Post by bavarianbrit » 20 Jun 2018, 21:20
Send the old spring to this firm they will copy and work out the spring rate from the material and dimensions. I have been there to the firm often on BMW projects and they reengineered a ballsed up design from BMW to make it work and they are of top quality. send it with a covering letter in english that will suffice, send it to entwiklungsabteilung Fa. Hirsch web site = https://hirsch-federn.de/fertigung/
Martin
gunnybedford
Post by gunnybedford » 21 Jun 2018, 19:46
Thanks Chaps for the replies, i have got a mate who lives in Germany to sound out the German company to see it the might assist, Clive sorry to sound stupid, whats the OD of the spring ?
22-250jock
Post by 22-250jock » 21 Jun 2018, 20:31
Outside Diameter :thumbup:
