led range
kingsy18
led range
Post by kingsy18 » 23 Mar 2017, 20:46
How much range would i benefit if i used a t67 over the t50 using a red led ,knowing the t67 is a heavy old lump would it be worth it.
richgas
Re: led range
Post by richgas » 24 Mar 2017, 14:14
kingsy18 wrote:How much range would i benefit if i used a t67 over the t50 using a red led ,knowing the t67 is a heavy old lump would it be worth it.
Depends if your using a airgun, rimfire or centre fire. Either of the first two then would not be worth the added weight of a t67. Centre fire out to 250 yds then yes. T67
andy66
Re: led range
Post by andy66 » 24 Mar 2017, 20:05
Kingsy are you using a basic ebay type red led in your t50?
kingsy18
Re: led range
Post by kingsy18 » 24 Mar 2017, 20:56
not sure what led it is but bought the torch from the torch factory
andy66
Re: led range
Post by andy66 » 25 Mar 2017, 08:31
Just took a look at their website and it does look like the basic led pill they use, if you do have some soldering skills you could triple the brightness from a simple new led, driver and unprotected batteries.
kingsy18
Re: led range
Post by kingsy18 » 25 Mar 2017, 10:00
soldering skills :crazy: ,wouldn,t know where to start,thanks for the advice anyway.
Re: led range
Post by some bloke » 25 Mar 2017, 11:17
andy66 wrote:Just took a look at their website and it does look like the basic led pill they use, if you do have some soldering skills you could triple the brightness from a simple new led, driver and unprotected batteries.
Yer not allowed to tease members like this... more details needed for those able - and do you supply them done? :angel:
poppy mae
Re: led range
Post by poppy mae » 25 Mar 2017, 15:02
Dave its as simple as using Noctigon copper bases, finding the best binn of red, red/orange led, 1.4 driver and away you go.Best part is rooting out the highest binns and then seeing the prices! Also dont forget why put a decent pill behind a crap lens? find the best lens as well. ......££££££££££££££ start adding up ,but quality costs.
Cornish fixer
Re: led range
Post by Cornish fixer » 25 Mar 2017, 15:48
:!: would there be anyone of you top blokes be able to make me up one of these top notch t20 pills in red ? got no diy skill what so ever ,more than happy to pay proper for one of these better quality pills cheers :thumbup:
Re: led range
Post by blueroll » 25 Mar 2017, 15:56
poppy mae wrote:Dave its as simple as using Noctigon copper bases, finding the best binn of red, red/orange led, 1.4 driver and away you go.Best part is rooting out the highest binns and then seeing the prices! Also dont forget why put a decent pill behind a crap lens? find the best lens as well. ......££££££££££££££ start adding up ,but quality costs.
"Crap Lense", pray tell more please ?
