Black sun2 or problem
hignet
Post by hignet » 21 Apr 2018, 11:59
Just after a little help having problems with the ir flickering on and off happened last night just about to take shot and ir went off also the head is very loose batteries are all good fully charged had a look but pill seems very tight to remove
Re: Black sun2 or problem
Post by some bloke » 21 Apr 2018, 12:11
The pill may have worked loose if that coincides with a flat top cell that may not be making a good contact because some are shorter than others.
Bear in mind it has a reverse thread - so you 'do it up' to undo it.
hignet
Post by hignet » 21 Apr 2018, 15:04
Thanks Dave didn't realise it was left hand thread been using torchy protected cell batteries seems like a loose connection if you tap it it comes on bit of a pain
Post by warbucks » 21 Apr 2018, 16:15
there are two blobs on solder opposite each other, check that there isnt a crack in the solder ------mine had this problem.
hairlesshunter
Post by hairlesshunter » 21 Apr 2018, 18:38
hignet
Post by hignet » 21 Apr 2018, 20:19
Cheers Dave had a look at the soldering all seems ok but can't find my magnifying glass eyes aren't what they used to be. I'll give hairlesshunters suggestion a go thanks for the link
poppy mae
Post by poppy mae » 21 Apr 2018, 23:36
If the pills not loose , give the spring a little stretch.....
hairlesshunter
Post by hairlesshunter » 22 Apr 2018, 13:53
hignet wrote:
21 Apr 2018, 20:19
Let us know how you get on if it doesn’t work Clive may be able to help
hignet
Post by hignet » 22 Apr 2018, 15:25
will do just trying to get my nightmaster torch back of a mate the nm batteries are slightly longer bought the torchy ones as spares and had not used them till recently
