WHAT SIZE?
RELOADER54
WHAT SIZE?
Post by RELOADER54 » 20 Jun 2018, 18:49
I have a perfectly good laserware x70 with the green pill, I would like to install a black sun or even a ruby pill,
a, is this possible?
b,what size would I need, as I have a t20 ir pill,[too small] and a t67 ir pill,[too big]
answers on a postcard please,,, :thumbup:
Andrew2235
Re: WHAT SIZE?
Post by Andrew2235 » 20 Jun 2018, 19:43
X70 I put a Ir black sun t 50 pill in mine but you have to cut about 8mm off the end of the tube wher you screw the pill in or the battery compartment is to long. I get 500yd plus off good clean light out of mine. I have 8 ir torches and it's one of my favourite
RELOADER54
Re: WHAT SIZE?
Post by RELOADER54 » 20 Jun 2018, 20:27
thanks for the reply, I can spin off 8mm no problem on the lathe, does it adversely affect the light/beam in any other way,,
Andrew2235
Re: WHAT SIZE?
Post by Andrew2235 » 21 Jun 2018, 13:55
No it works ok. the 8mm is the difference in the length of the pills the t50 pill is shorter. So if you just screw it in the battery doesn't touch. On one I cut the shoulder/ neck of the pill so it would screw in side the battery tube but that does two things . The lens/ head of torch can screw off and with the pill being down the battery tube it makes a very small spot beam. So I cut 8mm off or it is the difference in the length of the pills you are fitting
RELOADER54
Re: WHAT SIZE?
Post by RELOADER54 » 21 Jun 2018, 18:30
Sounds the way to go, just got to order a t50 black sun from wardy then,,,,better start saving up for the postage. :roll:
