T20 ir build
Pike25lb
T20 ir build
Post by Pike25lb » 18 Jul 2018, 12:30
Hi all I have a spare t20 with a cheap ir in been thinking would the ruby ir pill fit in one or one from irlightbuilds fit and can I get a yukon 50 mm lens to ad on my self
Or would it be better to just buy one already built a sunranger
Also I have a ward t20 ir not sure what ir model it is how can I tell
Also is it easy enough to fit a yukon lens 50mm to it
Would that improve it thanks
Re: T20 ir build
Post by cliveward » 18 Jul 2018, 14:36
Hi Pike25lb,
I used to use one of our Black Sun 2 in a 67mm T67 and have now moved over to a Black Sun Ruby in a standard T20.
I'm not finding myself wanting for more illumination and have saved a huge amount of weight on the rifle.
I would say try a Black Sun Ruby pill in your unmodified T20 first.
If you then feel you need even more range, turning it into a Sunnranger is as easy as chopping off a bit of the Bezel and then screwing the Yukon lens into it. :thumbup:
Re: T20 ir build
Post by sunndog » 18 Jul 2018, 16:27
blacksun ruby pill is the dogs
Plus you can always upgrade to a sunnranger if you need more
Pike25lb
Re: T20 ir build
Post by Pike25lb » 18 Jul 2018, 16:30
That's what in was thinking I have 1 of your t20 with a ir pill in it's a brass pill and has a white plastic cover thing around the led if you know what model is it
Re: T20 ir build
Post by cliveward » 19 Jul 2018, 10:52
Pike25lb wrote:
18 Jul 2018, 16:30
That sounds like an extremely old Oslon Black.
The T20 Black Sun Ruby Pill will go straight in: http://www.nightvisionstore.co.uk/black ... 2x24623160
The difference in performance will be absolutely massive!
