IR mounts to scope
sauer
IR mounts to scope
Post by sauer » 22 Jul 2018, 08:42
Hi folks
Ok I have an Antsupplies quick release mount that rings onto scope it’s ok .... was good price
(read cheapImage)
BUT find it’s quite “ loose” lot of play In it and it’s not finished the best ... easily marks the scope of not careful which difficult in the dark
I love way it on or off in a minute
Sooooo
What mounts are you guys using ?
That simple lad in use to put on or off scope
And solid stays where you direct it?
I’m using with a WD800L so needs to mount on scope not the NV unit
Paul
poppy mae
Re: IR mounts to scope
Post by poppy mae » 22 Jul 2018, 09:30
Image Morning , been using these for a couple of months , work a lot better than the type you have been using , there from wicked lights , got a friend to send a couple over from the states ......
sauer
Post by sauer » 22 Jul 2018, 11:25
So that looks like goes on to a pictinnay rail ... I do have a spare ring with pictinnay top I could use BUT ...... looking for something easier to obtain than coming from US of A.
Out of nosiness how much was that poppy if don’t mind me asking ?
Paul
poppy mae
Post by poppy mae » 22 Jul 2018, 11:29
$39.....
sauer
Post by sauer » 22 Jul 2018, 11:30
Not bad at all!
Just need to find em here now
poppy mae
Post by poppy mae » 22 Jul 2018, 12:32
The ones ive looked at were from Taclight or custom riflescopes , Laserlurch do a ball mount , deben/tracer do a ball socket torch mount and the usual adjustable mounts similar to what you have now , pleased with the ones im using now , scott country is the importer for wicked lights , as they dont ship internationally......
Andrew2235
Post by Andrew2235 » 22 Jul 2018, 13:59
Look on Amazon there is something that's looks like the smallest one £34 to £39
fizzbangwhallop
Post by fizzbangwhallop » 22 Jul 2018, 14:56
I’ve gone round the usual houses on torch mounts.....adjustable ones as per the first post to Optilocks rings screwed to QR lever mounts (too tight to buy the Laserluchs although Microglobe have them cheaper than anyone)...... I’ve ended up with these on Drone Pro’s, Photon Xtremes and more recently on one of Clive’s Adder’s on a mate’s day ‘scope...No faffing about and they keep the torch closer to the scope which helps to put the rifle’s mod in the shadow of the ‘scopes objective reducing glare back into the ‘scope. :thumbup:
https://www.ebay.co.uk/sch/i.html?_from ... _PrefLoc=1
The thumbwheel ones are easier to use than the nut ones and to align the torches I’ve only ever used a strip or two of bricklayers DPM to angle the torch body ...... various torches....NM800’s and T20/TR38 Sunnrangers.
I fitted them in conjunction with these where there’s no accessory rail on the scope...
https://www.ebay.co.uk/sch/i.html?LH_Pr ... t&_sacat=0
8-)
owl
Post by owl » 24 Jul 2018, 08:27
Another budget solution that works is this one:
https://m.ebay.co.uk/itm/High-Profile-3 ... h+pro.TRS0
(eBay search under ‘High profile QD torch mount’ if the link is duff)
In conjunction with one of the scope mounted picatinny rails that Fizz has linked to above, this will take a 50mm torch such as a Sunnranger etc. and clear the objective on a 56mm scope.
Lower QD mounts available for other smaller diameter torch/scope combinations.
https://m.ebay.co.uk/itm/30mm-25-4mm-Sc ... =R40&rt=nc
Post by blueroll » 24 Jul 2018, 16:21
I just use a normal 1" QD lever release scope mount and rotate the body of the torch in it for alignment. Seems to work okay with my Ruby Sunranger, T50 and NM800.
