nm 800
eddieh
nm 800
Post by eddieh » 11 Sep 2018, 12:51
Hi ive got a nightmaster 800 and can remember it being adjustable power but cant remember how its done, i know some part of it twists and you press the on off button half way to adjust but the only bits that twist on it seem to be battery cap and focus head..?
hazelted
Re: nm 800
Post by hazelted » 11 Sep 2018, 14:01
It's just a case of pressing the on of button softly not a full press.
Ted
Tikka.243
Re: nm 800
Post by Tikka.243 » 11 Sep 2018, 15:42
You slightly loosen the neck section behind the lens then you can use a slight press on the on/of switch to cycle the power settings.When the neck section is tight its full power only.
eddieh
Re: nm 800
Post by eddieh » 11 Sep 2018, 17:51
So is it the focus you loosen or further back than that as if it is it is very tight ?
Tikka.243
Re: nm 800
Post by Tikka.243 » 11 Sep 2018, 18:19
Further back between the head and battery compartment.
