Raymax 100
Gogreen
Re: Raymax 100
Post by Gogreen » 09 Nov 2013, 20:02
Thanx!
But that is so dissapointing.....
Could it be you have a 125 degrees versus 30 degrees? Then the 30 degrees is same as 125degrees but with optics...?
Plenty of space for the feet of those plastic Tir reflectors around it... just have to find a good enough match.
Just have one in the mail somewhere in a plain or train or by car.
Precise like this one from Ebay: RAYTEC RAYMAX 100 RM100-F-30-OL1, auction# 331056338561.
http://www.ebay.nl/itm/RAYTEC-RAYMAX-10 ... 4d147ed681
Edit: on Raytec's site they have the Raymax Classic and the Raymax Platinum. Hope is back on track.
Re: Raymax 100
Post by sunndog » 09 Nov 2013, 20:12
SikaStag wrote:Adam
There you go.
http://www.ledsupply.com/led-drivers/wi ... th-dimming
Ian
cheers me dears
oslon black drivers
SikaStag
Re: Raymax 100
Post by SikaStag » 09 Nov 2013, 20:13
You may be right. It well be a 120 degree. I am not 100% sure it was so long ago that I bought it. I checked my Ebay purchase history and it only lists the last 6 months.
The one I have differs from the one in your link. It has adjustments. The one I have has one wire going in and thats it.
Ian
SikaStag
Re: Raymax 100
Post by SikaStag » 09 Nov 2013, 20:15
Adam
If you need one. I bought 20 and will be buying more in. You could buy one off me at 4 times the price :oops:
Joking of course.
Pm me if you need one quick.
Ian
Gogreen
Re: Raymax 100
Post by Gogreen » 21 Nov 2013, 17:09
The one I got from the fellow on Ebay is 25W, from 12 to 24 volt.
It has a grey powdercoated heatsink, if it makes a difference to earlier versions.
The build is nice but it's use is limited.
It has 20 leds with TIR-optics. They glow in the dark but nightvision looks through the dark perpspex cover.
I found the intensity very dissapointing, maybe 20 metres at most, thats with a Gen2 tube.
Probably are the Osram Dragons.
Any trick to remove the cover without destroying it?
Seems to be glued or clipped non-reversible.
Re: Raymax 100
Post by phoenix » 21 Nov 2013, 18:10
Gogreen wrote:The one I got from the fellow on Ebay is 25W, from 12 to 24 volt.
Try a hairdryer around the edges for a few minutes and then gently try to lever off the the cover with a thin blade tool.
Gogreen
Re: Raymax 100
Post by Gogreen » 30 Dec 2013, 21:55
Opened mine up. The shell has a 4mm rim that is inserted with some Polymer glue to the aluminium base.
I dremeled it open, but if you make a craddle with 2 screws in the outer end for each corner you might have handle enough to pull it open without damaging the shell.
Raymax 100 Fusion, 25W.
Inside are 20 x Osram Dragon, the ceramic rectangular type, with TIR-reflectors clipped on to of it.
There are two boards inside, one with the electronics, and one with the leds, connected with a connectur. Doh.
They are wired in 4 rows of 5 in series. Each string got 8V delivering 1,6V to the led.
Its a very professional driver and heatsink, so I will probably change it to a white floodlight.
SikaStag
Re: Raymax 100
Post by SikaStag » 31 Dec 2013, 10:23
When I bought mine. I was hoping it had Osram Dragons fitted. Was well disappointed to see the 200 odd little lead's. The one you have should be a good thrower. I am assuming that if the rear of the Raymax has the dimmer facility ir will be the same as the one you have. If nothing but a single wire coming out of the rear. Do not buy it. It is the same as the one I bought.
Thanks for sharing the info.
Ian
chazuk
Re: Raymax 100
Post by chazuk » 16 May 2018, 21:53
I know this is a old thread but I have just bought a rm100 same as Ian’s the IR unit just a cable from each unit no adjusters on the back of IR unit.
The bulbs need replacing can anyone recommend what bulbs to use? The board will be same as in Ian’s post on page 1
chazuk
Re: Raymax 100
Post by chazuk » 16 May 2018, 22:01
I have just bought one of these a rm100 it’s a old unit without the adjusters on the back, the bulbs need replacing due to age can anyone recommend what to use and if it is possible? Board will be same as Ian’s picture on page 1
