viewfinder wiring info, please post your findings
22-250jock
Post by 22-250jock » 30 Jun 2013, 09:25
as suggested by Terry,
thought we needed a thread to help out with wiring for camcorder viewfinders
so the two model I have used are both old 8mm camcorders, the Sanyo VM-D66P and the Olympus VX42
they are in fact the same camcorder, just branded under different names ;)
the viewfinder is removed by simply undoing two screws and unplugging,
the wires as you look at the plug shown in the picture are, from left to right..........left. +5v....middle 0v (earth)....right AV.1v
hope this helps
Hilbily
Re: viewfinder wiring info, please post your findings
Post by Hilbily » 30 Jun 2013, 21:35
Minolta Master C-606
Red + 8 volts
Black -
Brown - Video
White + Video
Yellow ?
Wolff2233
Post by Wolff2233 » 30 Jun 2013, 23:02
Sharp VL-C670S
Black +5V
Red -
White +Video
genisis22
Post by genisis22 » 01 Jul 2013, 07:47
SANYO VM EX four wires green plug in hand, read from left to right brown 5v + grey neg grey vid grey 5v+
Hilbily
Post by Hilbily » 04 Jul 2013, 04:47
Sony 1-1/2" CCD DFX-3000 studio Viewfinder nice viewfinder has external knobs to adjust contrast and brightness
Pin #'s are marked inside the plug
#1 ground - black
#2 rec blue
#3 spare White
#4 Video - yellow
#5 batt indicator Grey
#6 Video + Red
#7 12v + brown
#8 spare orange
Mechanic775
Post by Mechanic775 » 09 Jul 2013, 11:25
Sony Handy cam
Has a stupid ribbon connector :problem: Major pain in the ass but i finally got it working
UbaHh
Post by UbaHh » 15 Nov 2013, 15:45
JVC GR-AX7EG
red 8v power
black ground
white video
brown -
yellow -
genisis22
Post by genisis22 » 23 Dec 2013, 08:29
sanyo vmex 580, color evf tft,
7 wire easy peasy this one if you think about it, cant go wrong same way around which ever end you start,
1 and 7 negs
2 and 6 5v +
4 video
3 and 5 spares
Viking27
Post by Viking27 » 04 Jan 2014, 07:20
JVC GR-AX25
Camcorder runs off 6v. Assuming viewfinder does the same. Works fine.
Connector with 6 wires. One is brown the rest are grey.
Starting with the brown wire to the left;
1 - + (Brown)
2 - + Video
3 - Gnd
4 - ?
5 - ?
6 - +
scorpion
Post by scorpion » 05 Jan 2014, 18:50
OLD type panasonic viewfinder 3 grey wires = pos neg and vidio feed one black common or ground.. :roll: :roll: will post pics tomorrow .
