viewfinder wiring info, please post your findings
richgas
Re: viewfinder wiring info, please post your findings
Post by richgas » 14 Mar 2015, 18:04
Mechanic775 wrote:Sony Handy cam
Has a stupid ribbon connector :problem: Major pain in the ass but i finally got it working
Hi, did you ever work out the voltage for the viewfinder. I applied 5v and is just sit there with a little red indicator lit
Cheers Richard
gypo
Post by gypo » 14 Mar 2015, 18:15
That's the same as I was getting, in the end I binned it
F
richgas
Post by richgas » 14 Mar 2015, 18:28
gypo wrote:That's the same as I was getting, in the end I binned it
F
We're your wiring connections correct. If I remember camera my CRT worked fine.
richgas
Post by richgas » 14 Mar 2015, 18:56
Paid £40 for the camera just for the CRT. Are you sure you wired it right before posting pictures. Hope i have not just burned up £40 :thumbdown:
gypo
Post by gypo » 14 Mar 2015, 20:22
F
Had the view finder for nowt, gave up on it after a bit and binned it :wave:
G
richgas
Post by richgas » 15 Mar 2015, 14:12
Ok in a nutshell how to find + - leads for CRT
1) live connection - look for capacitor +, square ones have a silver end. Google capacitors to identify your type. These are normally very close to connection block.
2) identify other side of capacitor for your negative.
3) connect your video neg and power neg to this point
4)unless video feed live, screen will be blank
5) touch live video feed to other cables until it works
6) mine powered up on a T20 battery. Don't over power, you may blow it.
Mr. FOG
Post by Mr. FOG » 17 Jan 2016, 14:20
KPC E700 + T20
Display power converter 5V DC / DC AM2S-1205SZ
http://www.aimtec.com/site/Aimtec/files ... AM2S-Z.PDF
Fredintheshed
Post by Fredintheshed » 05 Feb 2016, 08:50
morning all, will any camcorder with a separate viewfinder work ???
jfkenpoman
Post by jfkenpoman » 07 Feb 2016, 14:04
Just bought a canon v50 hi 8 camcorder from the bay......hoping that the viewfinder will be suitable. Anyone used one?
Here's the item number. *bay item number is 301858659544
https://www.google.co.uk/imgres?imgurl= ... MwggKAIwAg
Yurgen
Post by Yurgen » 07 Feb 2016, 16:20
As per the picture, you attached, the camera does not have CRT viewfinder, but LCD one. So I'm not sure your experiment will be successful.
