Cameras links and specs
Locked
jdk1
Post by jdk1 » 24 Nov 2013, 01:03
700TVL Effio-E 1/3" SONY Super HAD CCD II Color Camera Board OSD MENU
http://www.ebay.co.uk/itm/300891660907? ... 26_rdc%3D1
http://www.youtube.com/watch?v=ykMleNyA ... e=youtu.be
This is a good comparison video of this camera vs a watec 902h made by paulham
Good camera with an easy to operate OSD suitable for air or rimfire ranges using an 850ir T20 this came without a filter but be aware that could be different on the newer ones.
1/3" SONY 960H EXview HAD CCD II 700TVL 0.0003Lux D-WDR OSD 2D-DNR Motion Detection Privacy Mask HLM CCTV Video Mini Camera
http://www.aliexpress.com/store/product ... 93119.html
viewtopic.php?f=29&t=4775
Poppy mae and several other members are getting good results with this camera both as an add on and a spotter but poppys took 2 months to arrive so if you are in a rush for a camera this may not be the one for you
KPC-E700PUB Board Camera 3.6mm 1/3" 700 tvl 30mm sq
http://www.sure24.co.uk/kpc-e700pub-boa ... c-internal
viewtopic.php?f=29&t=4061&hilit=e700
viewtopic.php?f=29&t=3975&hilit=e700
Although not cheap this is proving to be a very popular camera as it uses the same internals as the excellent EJ230 but fitted into a small box which makes it a bit neater to mount behind a scope , also the link is to an english company that will give you a 10 percent discount if you mention this forum
Locked
