Air fill in an air arms s410
Glenn
Post by Glenn » 23 Dec 2017, 16:20
I have an air arms s410 carbine and just had it serviced.
I got it back and the air gauge said it was filled to 190bar but the most I can ever get it to is 100 bar and it has always been the same. Why is it and what can I do to get it to fill to 190bar. Could it be the air tank or gauge
Silent Shooter
FOUNDER
Re: Air fill in an air arms s410
Post by Silent Shooter » 23 Dec 2017, 17:52
What size air bottle are you filling it from ?
Geoff
Glenn
Post by Glenn » 23 Dec 2017, 19:11
Hi Geoff
I’m a bit green with all this. I have 2 bottles both 2ft high. They both have numbers and letters stamped in them but they don’t mean anything to me. Could it be the gauge,
Thanks for replying
Glenn
Silent Shooter
FOUNDER
Post by Silent Shooter » 23 Dec 2017, 19:35
You should see 300 bar or maybe less stamped on it somewere,if I remember correctly unless it's 300 bar you will never get a proper fill to 190 also if it is 300 bar on it possibly it needs filling and has run low.
Geoff
pav
Post by pav » 23 Dec 2017, 22:31
there a gauge on gun and air tank if it only going to 100 bar on tank I would say it needs filling so not enough air in bottle to fill gun
sauer
Post by sauer » 24 Dec 2017, 20:12
An older 232 bar cylinder will fill an air gun to 190 bar no problem
You can only ever get into the air rifle what is in the cylinder pressure wise never more. Unless you pump it .
All your doing is decanting existing pressure from one vessel to a smaller vessel .
If all you can get is 100 bar .... check the pressure in your dive cylinder it maybe only at 100 bar therefore that’s all your gonna get until you get cylinder refilled.
If you don’t know what your doing I strongly suggest you get someone to show you ......
I’ve seen too many people mistreating pressure and it can kill.
To give you an idea
Your car tyre is 30 psi or approx 2 bar
A dive cylinder at 232 bar is approx 3000 psi plus !
It’s same enough just be aware and follow procedures
Paul
Glenn
Post by Glenn » 25 Dec 2017, 09:37
Thanks for the info Paul, very interesting
I don’t know anybody knowledgeable that would come and look at it unfortunately
blueeyes
Post by blueeyes » 25 Dec 2017, 16:01
As Paul says safety is paramount dont try anything with alcohol in you , have a look here plenty of other vids give you a good idea ,so you know what you should be doing :thumbup: https://www.youtube.com/watch?v=byE64kiSRa0
kb1065
Post by kb1065 » 12 Feb 2018, 15:47
blueeyes wrote:As Paul says safety is paramount dont try anything with alcohol in you , have a look here plenty of other vids give you a good idea ,so you know what you should be doing :thumbup: https://www.youtube.com/watch?v=byE64kiSRa0
Be better with quick release valves
Post by some bloke » 12 Feb 2018, 19:15
I suggest you get the air bottle to a diving centre that does bottle fills before trying anything else because it sounds like its getting 'empty' and may need its periodic dive bottle test too.
