PULSAR APEX XQ50 LRF
scirroco
Re: PULSAR APEX XQ50 LRF
Post by scirroco » 06 Jan 2018, 04:36
Hi anthony,glad you have your thermal at last..please keep us updated on what you think of it good or bad
Enjoy
Rgds steve
anthony
Post by anthony » 07 Jan 2018, 09:22
yes willdo bud i just need to sort out a rail for my 223 Sabbatti Lightweight sporter
Theoben Rapid 7 Mk2 fac 30ftps 3-9x50 AG + AWT Silencer
Ruger 10-22 / Tasco 3-9x50 AG + Gen3 Dipol
CZ 17 HMR / Tasco 3-9x50 AG + PVS14
223 Sabbatti Lightweight sporter Nikon Monarch 3 4-16x50 SF + PVS14
Post by blueroll » 07 Jan 2018, 13:26
And let us know if you get any temp related zero shift please.
anthony
Post by anthony » 07 Jan 2018, 13:41
blueroll wrote:And let us know if you get any temp related zero shift please.
yha i wiil do bud
anthony
Post by anthony » 08 Jan 2018, 18:18
i went out with the Trail for the frist time last night i only used it as a spotter
as i have to order a Dovetail to Weaver / Picatinny Rail for it to fit my gun
anyway when i was using thermal lastnight ever so often it would freeze for a second or two
it did it 5 or 6 times i have no idea why its doing this? i have sent a pm to ian im just waiting for him to get back to me
to see why its doing this? but apart from that its was it was excellent /what a game changer
scirroco
Post by scirroco » 08 Jan 2018, 18:39
Hi anthony
Try alan rhone for a recnagel to picatrinny adaptor..ok the freezing is when the unit is re calibrating..
This does not happen with the ward wt series of scopes!!! If you ever want to look through 1, i am arrange a viewing my friend has the 75-3 35- 3 and soon a 50-3 will be a available also..you are not far away ab an hour..
But the only trouble with looking through 1 is you would want to buy one!! They are absolutely fantastic
Rgds steve
curlew
Post by curlew » 08 Jan 2018, 19:47
i have the trail andyou can set it for auto calibrate like you describe or semi where it will just do it when you press the button (if image degrades thru time while viewing) then there is also manual i think where the shutter does not close but you cover the lens instead.
i have noticed a countdown on the display so the calibration does not spoil a shot too .good idea.
Post by blueroll » 09 Jan 2018, 09:43
curlew wrote:i have the trail andyou can set it for auto calibrate like you describe or semi where it will just do it when you press the button (if image degrades thru time while viewing) then there is also manual i think where the shutter does not close but you cover the lens instead.
Have you suffered any POI shift from external temp change, ie home/room temp to outside for a while in the cold nights ?
andy66
Post by andy66 » 09 Jan 2018, 18:14
Depending on your shooting setup the cold or hot does cause poi shift and it can cause some weird results too.
Post by blueroll » 09 Jan 2018, 19:50
Hmmm. Shooting setup ????? Weird results ???????
