Pulsar Updates
AnthonyR
Re: Pulsar Updates
Post by AnthonyR » 19 Jan 2018, 13:42
Well it's not all rosy unfortunately, the Helion works fine but the sound on my Trail is very very quiet and not great quality, so still needs a bit of work.
If anybody else who has a Trail can give it a go and post up their results I would appreciate it.
Mini Magnum
Re: Pulsar Updates
Post by Mini Magnum » 19 Jan 2018, 14:21
Sound does not work in stream vision using an IOS device, probably an AVI format conflict although you can convert to mp4 and it works using iconv app
Sound work on android using Stream vision when downloaded.
Sound works using the video lead to PC
Menu brightness adjustment now works also black/black and white/white reticule the same as on the Apex models..
AnthonyR
Re: Pulsar Updates
Post by AnthonyR » 19 Jan 2018, 14:35
All of my tests were done by transferring the files to my PC, the files now won't play using Windows Media Player, but work using VLC player.
Was your test using a Trail or a Helion, if it was a Trail was the sound volume OK?
Mini Magnum
Re: Pulsar Updates
Post by Mini Magnum » 19 Jan 2018, 14:49
Trail tested, although I can test with Helion also now.. Sounded very slightly muffled, I was pretty close... but it was ok...
pav
Re: Pulsar Updates
Post by pav » 19 Jan 2018, 15:20
Sound not to bad in mine either although think it's a bit muffled with mouth been to close to mike mine will only play back in vlc now aswell
fizzbangwhallop
Re: Pulsar Updates
Post by fizzbangwhallop » 19 Jan 2018, 15:27
Brill!Done. :thumbup:
Not too fussed about the sound but the icon dimmer is gratefully received.
Where's the mic on the XP50? Can only see a little hole on the underside.......... :think:
8-)
Mini Magnum
Re: Pulsar Updates
Post by Mini Magnum » 19 Jan 2018, 16:04
fizzbangwhallop wrote:Brill!Done. :thumbup:
8-)
Probably in the little hole, just tried the Helions sound pretty good.
fizzbangwhallop
Re: Pulsar Updates
Post by fizzbangwhallop » 19 Jan 2018, 16:33
8-)
:thumbup:
Anybody managed to get anything to download on their iPads/iPhones? Just spoken to a mate trying to download to his iPad and his streamvision still crashes out? His xp50’s card is full and even formatting doesn’t clear it out.
8-)
Mini Magnum
Re: Pulsar Updates
Post by Mini Magnum » 19 Jan 2018, 17:32
Delete the app on your phone/tablet and reinstall
