Thermal or night vision
Mini Magnum
Re: Thermal or night vision
Post by Mini Magnum » 05 Feb 2018, 18:34
If you want 100% ID and the ability to increase your magnification upto 20-24x with the right torch/scope and the ability to not only see but take shots out to 400yds, I would get a Ward 800...
If you going down the thermal route a Trail XQ50 or Apex XQ50 LRF offer great features and performance for the money you pay, if you want a better image and more magnification look at Clives WT-75-3
glencunningham
Post by glencunningham » 06 Feb 2018, 06:00
Thanks for your input guys I haven’t managed to check out my helion xp50 at set distances to get an idea if trail would do the job.
glencunningham
Post by glencunningham » 06 Feb 2018, 21:36
Mini magnum I can’t pm you seemingly I don’t have permission are you on SD
Silent Shooter
FOUNDER
Post by Silent Shooter » 06 Feb 2018, 23:07
glencunningham I have checked and I can't see any problems with your pm box,I've sent you a pm please confirm if you received it or not.
Cheers Geoff
glencunningham
Post by glencunningham » 06 Feb 2018, 23:12
Hi Geoff received pm but when I reply and send message. I then get a message pop up saying you are not authorised to send private messages
Sent from my iPad using Tapatalk
Silent Shooter
FOUNDER
Post by Silent Shooter » 07 Feb 2018, 00:13
Ok I will take another look to see what's going on.
Silent Shooter
FOUNDER
Post by Silent Shooter » 07 Feb 2018, 00:22
Hi Glen if your using Tapatalk trying loging in to the forum and sending a pm,it could possibly be taptalk that's causing a problem.
Geoff
Muskett
Post by Muskett » 07 Feb 2018, 16:27
Now no DP, then a WDV800l with Clive's Sunranger Ruby with a compatible scope such as a Sidewinder probably gives the best and most variable option now done digi wise. High magnification and on open fields hard not to like. Budget for complete setup £1,300 or so.
As said Pulsar's N series just isn't good enough over the Photon.
Thermal then its the WT1's. As you have a thermal spotter you can work out if its the technology you want to use as a scope. A bit Marmite, some love it some don't. Much bigger "ask" than as a spotter.
dunker
Post by dunker » 11 Feb 2018, 16:53
Thought about tubed ? ATN mars x6 only need ir on darkest nights."excellent piece of kit".
glencunningham
Post by glencunningham » 11 Feb 2018, 18:50
I think the problem is not being able to try them. That’s what happened with the photon 6x50 I bought and couldn’t get on with so sold it and as per normal took a hit on it.
