Thermal or night vision
Sussexsteve
Re: Thermal or night vision
Post by Sussexsteve » 13 Feb 2018, 07:34
After using Pvs14 and drone pro I now use Ward Wt1 75-3 which blows me away still every time I turn the unit on. Had a Pulsar xp38 waste of money. My mate has the xp50 trail I zeroed that in for him the other day not impresssed !
jackal1
Post by jackal1 » 13 Feb 2018, 10:03
I have just zeroed a pulsar xd75 in for a keeper i know. Quite honestly i didn't think much of it and certainly wouldn't swap it for my drone.
glencunningham
Post by glencunningham » 13 Feb 2018, 10:19
Thanks for your input guys I think I’m swayed towards the Ward WT1 75-3 just need to see what’s the best price I can get one for and check if it’s due an upgrade before I take the plunge.
Post by phoenix » 13 Feb 2018, 11:18
The best price you can get one for is the best price you can screw out of Clive - he's the only supplier - unless you want to buy direct from China - and that will work out much more expensive - trust me I've done it.
I don't believe there are any upgrades for these scopes.
glencunningham
Post by glencunningham » 13 Feb 2018, 13:00
I’ll give him a shout
dunker
Post by dunker » 16 Feb 2018, 21:26
Good vids on you tube.
Sussexsteve
Post by Sussexsteve » 20 Feb 2018, 18:19
I run an XP50 Helion and the Ward WT1 75-3 is on par but obviously much more mag on base values. My mates trail XP50 compared to my ward magnification at 1.6 is 6 then 3.2 is 12 and 6.4 is 24 in terms of clarity
glencunningham
Post by glencunningham » 24 Mar 2018, 16:01
I think the consensus is that the WT1 75-3 is what I should go for
I've been so busy at work just haven't had a Minute..
Thanks for all your input.
Sent from my iPad using Tapatalk
Sussexsteve
Post by Sussexsteve » 24 Mar 2018, 18:05
Check out my you tube channel ukfoxshooter might help make your mind up
https://youtu.be/SgYyoncOUKw
scirroco
Post by scirroco » 25 Mar 2018, 10:47
glencunningham wrote:I think the consensus is that the WT1 75-3 is what I should go for
You wont go wrong with the 75-3, its absolutely out standing ,its shutterless ,so no freezing image with it re calibrating, an absolutely great piece of kit,
Buy with confidence
Rgds steve
