repeatablle mounting xq50
JP1
Post by JP1 » 25 Mar 2018, 08:53
Anyne tested the return to zero after removing and reattaching a trail xq50?
John
pav
Re: repeatablle mounting xq50
Post by pav » 25 Mar 2018, 11:58
I have mine set for 3 guns in the a.b.c in menu when I change guns there usualy a click or two out but only on airguns
anthony
Post by anthony » 25 Mar 2018, 12:44
i have mine set on 4 guns a 223 / 17mr /22rf /22 Rapid and never had a problem
Theoben Rapid 7 Mk2 fac 30ftps 3-9x50 AG + AWT Silencer
Ruger 10-22 / Tasco 3-9x50 AG + Gen3 Dipol
CZ 17 HMR / Tasco 3-9x50 AG + PVS14
223 Sabbatti Lightweight sporter Nikon Monarch 3 4-16x50 SF + PVS14
spready
Post by spready » 13 May 2018, 06:58
I’ve just got one of the pulsar qd locking mounts from the states at claims to return to zero, it certainly does do that, more than happy with it, it’s brilliant
andy66
Post by andy66 » 14 May 2018, 20:35
If your using the supplied mount get the pulsar 1nm torque wrench (about £15) to tighten the bolts also ensure you mount it in the same place each time pushing the scope lightly in the forward direction when tightening and you will have RTZ each time. I had a good test with mine on 3 rifles last weekend taking it on and off about 10 times between each shots and all were exactly in the same place.
Mini Magnum
Post by Mini Magnum » 15 May 2018, 08:00
andy66 wrote:
14 May 2018, 20:35
Agree great advice :thumbup:
Post by blueroll » 15 May 2018, 12:26
So That Pulsar torque wrench is fixed at just under 9 inch pounds ?
fizzbangwhallop
Post by fizzbangwhallop » 15 May 2018, 17:06
http://www.microglobe.co.uk/advanced_se ... sar+torque
Got one or two... works well with Clive’s thermal scopes... but I carry a thumb wrench as sold by Wilkos in my jacket for swapping scopes up a high seat.... dirt cheap, the socket was more!
https://www.wilko.com/search?q=Thumb+wrench
