Warden Adder Scopecam
pav
Re: Warden Adder Scopecam
Post by pav » 11 May 2018, 13:51
Am I rite in thinking if the battery goes flat and you have a spare 18650 battery I could change it in field Clive
Post by cliveward » 11 May 2018, 13:59
pav wrote:
11 May 2018, 13:51
Hi pav,
Yes just swap it over like you would a torch or IR. :thumbup:
Cornish fixer
Post by Cornish fixer » 11 May 2018, 14:53
Hi Clive how would this work on some of the better day scopes lens ,would it still be a cra!!picture or would you still need a mamba /sidewinder :
Post by cliveward » 11 May 2018, 15:04
Cornish fixer wrote:
11 May 2018, 14:53
I have a sneaky feeling that this will be useale on a lot more scopes.
If you have a less compatible scope (that's what I've been testing with) you can knock the scope mag right down and the make up the magnification using digital zoom without any loss of quality.
My test scope bottoms out at 4.5x mag. With the Adder fitted this is now about 9x which I find pretty much perfect. If you needed to you could use digital doom to bring that up to 18x or even 31.5x!
I also expect that if you have a fixed variable like a 2.5-10 or a 3-12 then on the bottom end, even without focus ability, using a Black Sun Ruby you would get enough depth of field for it to be very useable. Again using digital zoom to gain magnification should you need it. 8-)
Chrissmith0881
Post by Chrissmith0881 » 11 May 2018, 16:25
Would be interesting if you could do a few clips with it on the stac Clive to see what it's like on that!
Cheers Chris
Post by cliveward » 11 May 2018, 16:57
Chrissmith0881 wrote:
11 May 2018, 16:25
Cheers Chris
I've not got one to test with here at the moment, but it will be very good.
The scope I have been testing with and doing the videos with, isn't particularly amazing with add ons so the S-Tac should be quite a lot better. :thumbup:
pav
Post by pav » 11 May 2018, 20:04
cliveward wrote:
11 May 2018, 13:59
pav wrote:
11 May 2018, 13:51
Hi pav,
Sounds good Clive I suppose I best get one orderd cheers allan
Post by cliveward » 11 May 2018, 20:41
pav wrote:
11 May 2018, 20:04
cliveward wrote:
11 May 2018, 13:59
pav wrote:
11 May 2018, 13:51
Hi pav,
Hi Allan,
No problem. :thumbup:
Still got some available on the next delivery due to arrive Tuesday so not long to wait at all. 8-)
pav
Post by pav » 11 May 2018, 21:45
cliveward wrote:
11 May 2018, 20:41
pav wrote:
11 May 2018, 20:04
cliveward wrote:
11 May 2018, 13:59
Hi pav,
Hi Allan,
Do i just order strate off your website
Post by cliveward » 11 May 2018, 23:23
Yes you can order directly here:
http://www.nightvisionstore.co.uk/warde ... 2x26124662
