warden adder
Chat about your shooting and hunting. (Nothing illegal or cruel, please). Post pics or videos.
pav
warden adder
Post by pav » 17 May 2018, 23:59
quick video of first time out with it https://youtu.be/ZvP0hUrfOhg
fizzbangwhallop
Re: warden adder
Post by fizzbangwhallop » 18 May 2018, 06:09
Good shooting Pav! :thumbup:
8-)
Re: warden adder
Post by phoenix » 18 May 2018, 06:42
Great shooting and I liked the use of the rangefinder.
telf
Re: warden adder
Post by telf » 18 May 2018, 07:08
nice one pav , looks as though scope choice and as in clives videos the br20 will bring out the best in the little unit,did you have to put a stock extension on or move the scope forward for your head position ,all in all looks ok though look forward to some more footage
pav
Re: warden adder
Post by pav » 18 May 2018, 08:57
fizzbangwhallop wrote:
18 May 2018, 06:09
8-)
:thumbup:
pav
Re: warden adder
Post by pav » 18 May 2018, 08:59
phoenix wrote:
18 May 2018, 06:42
Cheers Bruce I use the same rangefinder on the thermal scope cudnt be without one
pav
Re: warden adder
Post by pav » 18 May 2018, 09:05
telf wrote:
18 May 2018, 07:08
Yep a better scope would be better it was only a cheep Hawke scope I moved scope forward about An inch lucky the fx impact is less forgiving than a wood stock gun with it been semi bullpup and has a long weaver rail but the add on is very small cheers
slimbo1973
Re: warden adder
Post by slimbo1973 » 18 May 2018, 15:17
pav wrote:
18 May 2018, 08:59
phoenix wrote:
18 May 2018, 06:42
How do these work with thermal? Is it hard to calibrate
Stew
Shit Shot Stew
pav
Re: warden adder
Post by pav » 18 May 2018, 15:32
Mines the mk5 version it has a red laser you can turn on top instead of the v site it bolts to weaver rail on side of gun has adjustable mount I just aim gun at tin foil iv zeroed on turn laser on and adjust till it hits tin foil then turn it off and it's not used again iv checked and the red laser his same spot as laser on rangefinder hope that makes sense
jdk1
Re: warden adder
Post by jdk1 » 20 May 2018, 09:28
Here is a little bit of filming with the adder , this was the first time out with it so it will probably get better with a bit of fine tweaking and actually putting it on straight :roll: , the scope is a bushnell legend 5-15x40.
https://vimeo.com/270936635
https://vimeo.com/270936749
