Pistol Grip Spotters. New specs and prices from October 2017
Post by some bloke » 01 Jan 2017, 18:48
Please go to the next page to see the newer spec and prices from October 2017.
Pisces
Re: Pistol Grip Spotters - Reduced for 2017
Post by Pisces » 12 Jan 2017, 09:45
Hi Dave, I definitely want a Black Sun version at £230 please
PM to sort out shipping will follow shortly.
bighit1985
Post by bighit1985 » 20 Jan 2017, 20:52
Hi. Where about are you for collection out of interest??? Cheers
bighit1985
Post by bighit1985 » 20 Jan 2017, 20:54
Also forgot to ask. It may have been already said but what's the range of the spotter?? With the t50 and the black sun???
Post by some bloke » 20 Jan 2017, 23:50
bighit1985 wrote:Also forgot to ask. It may have been already said but what's the range of the spotter?? With the t50 and the black sun???
300 yard rabbits are very small on the monitor but can be seen if you have good eyesight.
Foxes are of course larger on the screen and easier to spot, and eye shine at circa 500 yards
Foxbuster
Post by Foxbuster » 23 Jan 2017, 21:50
Hi Dave,
I'll take one of the 50mm with black sun for £243 delivered please
Pm sent.
Cheers,
Chris.
Post by some bloke » 05 Feb 2017, 13:06
Elevate the height on your sun roof or to view over grass etc with this very sturdy tripod handle screwed into the base of the pistol grip for an added £25.
Post by some bloke » 21 Feb 2017, 20:17
I'm offering a different lens type for my integrated torch spotters. I think the new type are the same as those used in the Pitch Black rig that was around a year or more ago. I will be using 50mm and 35mm focal lengths.
Although the 1/3" format lens are quoted at F1.2, I'm not 100% convinced they let in more light during my low light comparisons than the 2/3" format F1.4 C mount lenses that are commonly used for spotters but they have subtle advantages for truck spotter use:
Their fine M12x0.5 fixing thread allows much better focus precision than the coarser adjustments of other lenses - this makes the spotter much more point and shoot friendly over a much wider depth of focus - and handling won't accidentally nudge them out of focus.
They're slightly slimmer - leaving more space for a larger torch head on a small box.
And they don't need as much of the E700 camera neck removing.
I don't want to say where they are coming from just yet and they won't be much use to anyone on their own because they are too likely to get knocked out of position during handling in the dark for example as seen here:
I have made a 4 screw supporting lens shroud to prevent knocks or handling/storage pressure from pushing them off aim.
Cornish fixer
Post by Cornish fixer » 22 Feb 2017, 17:46
Hi Dave, what's the price of your suction mount spotter with best lens and as pill in the ir cheers bill
Post by some bloke » 22 Feb 2017, 22:19
Hi Cornish, the Black Sun pill option is £243 with RMSD P&P.
The pistol grip or the suction mount are the same price - unless you want them both - if so please add £7.
I currently have them ready to go with the switches and new lens to the right or left, please specify left or right when you order at the bottom of this thread. Handles/suction mounts are removed to fit in smaller boxes and re-fitted by the buyer - pliers or 11mm spanner needed to fit the nut. The tripod handle in this image is not included:
