Wanted Cheap side focus scope
gunnybedford
Post by gunnybedford » 08 Apr 2018, 19:20
Hi
Thinking about changing the scope on my .22LR, to one with side focus to make things easier with a ward NV add on. So was wondering if anyone had one for sale ? As its going on a .22LR don't need anything to exotic or expensive ! would prefer a mildot reticle and ideally tactical adjustable type turrets, anything out there that might be suitable ? thanks Neil
JCS1993
Re: Wanted Cheap side focus scope
Post by JCS1993 » 11 May 2018, 14:32
Hi,
This may be a bit too much for a .22 but i have a Nikko Stirling Diamond Long range 6-24x50 for sale. In basically as new condition and has tactical turrets /side focus. Would let it go for £180
Thanks :thumbup:
Jon
anthony
Post by anthony » 12 May 2018, 06:45
i got as new still boxed 30mm tube 6-24x50 Side PA Deer Hunter scope for £70 posted i can send you some pics if your interested
Theoben Rapid 7 Mk2 fac 30ftps 3-9x50 AG + AWT Silencer
Ruger 10-22 / Tasco 3-9x50 AG + Gen3 Dipol
CZ 17 HMR / Tasco 3-9x50 AG + PVS14
223 Sabbatti Lightweight sporter Nikon Monarch 3 4-16x50 SF + PVS14
sauer
Post by sauer » 14 May 2018, 16:29
I might be onto nothing here but. Have a fox firearms 4x16x50 side focus scope not for sale but my point is I’m going to try it with a NV add on and if it is ok you can buy these for around £100 new and very good AND with target turrets ... they brought in to fox firearms and service I’ve had always good ... I was told they are brought in by other people under a different name ( wasn’t given it ) & rebadged and around £350
I’m hopeful it will be fine for NV add on
Paul
Cornish fixer
Post by Cornish fixer » 15 Jun 2018, 13:46
Hi how did you get on trying this scope with your n,v ???
Post by blueroll » 15 Jun 2018, 21:15
Cornish fixer wrote:
15 Jun 2018, 13:46
If your still looking I may have a Nikko Stirling LR Diamond 4-16x50 Hold fast ret or a MTC Mamba 4-16x50 RIR no.4 ret available soon.
sauer
Post by sauer » 16 Jun 2018, 06:48
I went to try it and initially it looked good but within minutes I broke the side focus wheel so I sent it away see if repairable ... it was .... bit 2 Nd time this happened and guy who fixed it said was common fault as not greatest design internally ... kind of put me off ...... I think will work but I’m in desert for last two weeks & another three to go so I won’t get to try till then ..... I bit bullet and bought a Sightron S-tac the 3x16x44 or 42 version so that will be main scope to use with waddy add on ... lot of experimenting to do when home ...... I’ll keep fox fire arms scope on an air rifle to use and. Still have an add on Bruce made me I can use on it as well as wardy
Paul
